I have felt for a long time that my pest control company was not worth the monthly cost. Now I have been informed that the price is to be increased yet again. It has been my belief that the homeowner cannot buy the industrial strength insecticides that can be used by a professional licensed bug company. This belief, of course, has been fostered by the bug company I use.
So here is my question to any who may have experience in this area. Are there chemicals that can be purchased by the average homeowner that are nearly as effective as the professionals use. I don't care if I need to apply more often, just need to work well. I live in a arid desert environment in Arizona if it makes a difference and it needs to be non-toxic to pets, birds and larger animals.
BTW, I have tried to find this info on the web and find biased commercial information and confusion. Thanks for any help and I wish this was woodworking related. John
>When we bought our house last year, it had a history of rats in the crawlspace. House is on a heavily forested lot. Previous owner had a "Terminex" contract, the company said in writing there was "no evidence of rodent activity in crawl space". This was at least the 2nd company who had worked on the problem for this owner. I had a 3rd, independant company inspect right after we moved in, same verdict, no rats. Since then, I have trapped 2 rats down there & closed off 2 pretty obvious points of entry. So much for the "professionals". I have been getting industrial strength poison & modern rat traps (not those "lose a finger" wooden ones) from the company at the link below. Haven't seen any signs since using this poison & closing off the entry points, knock on wood. So to answer your question, yes you can get full strength chemicals, in most states at least.
BTW, I'm using the single-feed bait FINAL in my bait boxes, about $48 for a 9# pail, which is a lot.
>John, like you, I thought there had to be something better than what I was being told by the bug people. I read up on the spray that is available on the internet. I then ask the bug man that sprays at our church if he had heard of this spray. He told me that was what they use for general spraying. The insecticide is demon WP (wetable powder). I found it on the web being sold for $12.75-$25. The cheapest place was ePestSupply in Dallas, TX. It comes in 4 packets enclosed in a tinfoil envelope. I had crickets coming out the ying-yang but after one spraying the crickets are silent. In fact we have not seen any buys! Best of Luck
>Some chemicals require a license, some don't. And oddly enough some are not allowed to professionals but can be got by homeowners (the idea is that homeowners won't use much) or may be available to homeowners for a while after pros can no longer get it. For a while there was a herbacide (don't recall which one, this was when I was in college maybe a decade ago) that could be bought in small bottles in garden stores or box stores but was banned for large scale application such as professional companies and farms.
The real question is what level of pests and/or hassle do you want to put up with. For me some good hunting cats and keeping spiders around and encouraging birds and bats keep the pests low enough they don't bother me. No chemicals, no hassle, no bug company. If that level isn't acceptable for whatever reason then go to your local coop, box store, hardware store, garden store and look at the lables of various bottles and the MSDS {Materials Safety Data Sheet [tells you how hazardous to you and other critters]). Pick 2 or 3 to rotate between every two or three aplication cycles (rotating the poison will help prevent resistance) and make sure the active ingredient is different. And regular application will be necessary, some require once a month some every few months. If that is too much hassle and you still don't want the pest level of natural controls then the only option left is to pay a pro.
>Look up borate for pest control and see if it will solve the problems you encounter. In various formulations it can control everything from roaches to termites. Readily available from web sources and pretty much nontoxic to animals.
>for our home. If you dont know Texas then you don't know about the huge tree roaches that are everywhere. They are so big you can hear them coming down the hall. Because the fly and are often found in trees they have an easy time getting into your house. I found a gallon of some clear bug spray at HEB, a grocery chain in that part of the country. That stuff was good. I learned early on that you need to wear a mask to apply the stuff, because it could choke you up real fast. I would clear out all the closets and cupboards and spray all the corners really well and then let it dry. If there were any cockroaches or other bugs around they were kaput and one didn't see another bug for months. I never tried it on fire ants but was tempted to. That stuff was better than what the bug man used on my sister-[in-[law's house.
Another vote for ePetSupply as a handy resource for info and chemicals. Generally I try to avoid potentially harmful chemicals around the house, but they were a source for boric acid crystals (much cheaper than a ready-made solution) to treat powder-post beetles. I had a bad (but comical in a way) experience with a "professional" exterminator. Long story short. Turned out it was small brown bats in the attic of a rental property, not rats. The exterminator went into the attic, freaked out, and then clubbed them all with a baseball bat. Only later did I find out that brown bats are endangered and that the correct solution is to wait until they exit and then simply plug the entrance hole. Lesson learned.
It's too bad that some people have such a fear of all little life that their first instinct is to kill it.
As a beekeeper, what I've learned to fear is those who routinely dump pesticides on their yards and gardens without even knowing if they have a pest problem. "Preventive maintenance."
If we dust flowering plants in the garden or yard with pesticides we may well kill off the remaining colonies of bees in the area. Not only do we kill off all the scary unknown bugs, but the bees will take the poisons back to the hive and share them with the others. Bees colonies two miles or more away can be injured or destroyed.
I've known people that were so afraid of getting stung that they sprayed the grass in their yard since they saw bees on the clover. A fact: honeybees foraging for pollen and nectar are not the least aggressive. You can pick one up in your hand and they will not sting unless you pinch it. (Mess with their home and it's another story!)
Honeybees are responsible for nearly one out of every bite of food we put in our mouths. With all the difficulty in the US with keeping honeybees alive due to parasites and diseases, it's a shame some are killed off due to ignorance.
If pesticides must be used on crops, there are guidelines for large scale application (by farmers, etc). Note that the person who applies the pesticide is can be legally responsible for damage to bee colonies.
- Apply pesticides only when needed.
- Use the recommended pesticide at the lowest effective rate.
- Use the pesticide least hazardous to bees that will control the pest involved. If all recommended pesticides are equally hazardous to bees, use the one that has the shortest residual effect.
- Use sprays or granules instead of dusts.
- Use ground equipment instead of aerial application to apply pesticides near bee hives.
- Apply pesticides in late afternoon or at night when bees are not working the blooms.
- Avoid drift of pesticides onto plants that are attractive to bees.
- Notify beekeepers several days before applying any pesticide that is hazardous to honey bees. This will give them a chance to protect their colonies. However, notifications are not a release of responsibility.
For gardeners and those applying pesticides by hand, please don't EVER apply pesticides to blossoms. If possible, apply when the plants are not blooming, otherwise, try to apply only to the leaves. The link below has tables of the relative toxicities various pesticides.
As for this thread and treating the house, I would want to know exactly what insects I am fighting in my home before using any pesticide. Some insects require specific treatments.
I personally spray the exterior of the house in the fall to discourage ladybug invasions and eliminate carpenter bees. Both of these treatments are very successful if done at the right time. To discourage termites, I've read it's important to keep leaves and sticks and firewood away from the perimeter of the house and keep roof, gutters, and drainage around the house in good repair to keep things dry. Termites love warm moist places. Twice we had termites cause our underground high-voltage electrical service line to explode by building a nest in the transformer box which bridged the 7200v line to ground. There was no wood in there for them to eat but they were attracted to the warmth. I now keep the leaves away and occasionally pour a bit of bleach water into the dirt around the concrete transformer pad.
One more thing - some pesticides like malathion are extremely hazardous to mammals (people). Others, like permethrin, are quite safe for people and most mammals (except cats). I always wear a full-face respirator mask with organic vapor cartridges (not one made for particulates/dust).
>My guy stops every two months. I pay him a bit less than a once-a-month x 2. So I'm saving money. I'm working at home ( stealth gloat ) so he is my break for that day. He spends about an hour on the outside and inside. I like him and he seems to want my money. While we're talking he takes his time and REALLY hoses down the outside, inside the garage and the workshop out back.Then we stroll through the house spraying and talking. I asked and, yes, they " rotate" their chemicals every two or three months. I think the " give-a-damn " attitude is key ( like every other service ). Orkin runs through the house with their little areosol can and done in ten minutes. Hmmmmmmmmmmmmmmmm. Not much kill'n go'n on there. I want carnage. Don't want to go get the stuff ( or order it ), mix it ( or whatever ), keep track of where I've been then, blame myself when theres a critter. Rather have Dude come back out for free. Dude comes every two months, we jabber for awhile and I forget all about it for another two months for fifty bucks. Oh, hes got me set up with about five mouse bait stations ( I'm paranoid ) in the same price. I figure I can't beat that doing it myself. I get ( dare I say it ? ) Lee Valley service from my guy. Look around, they're out there.
>Here on the farm we do all our own spraying. An in-town friend was being charged a huge rate to control an invasion of violets in his lawn and he asked my advice. I told him to request a MSDA sheet for what the lawn company was spraying. I am not certain , but I suspect people that spray must produce a MSDS for anything they used on you. Anyway, he got the info on what they were using. It turned out to have the same active ingredient that I use for pastures and it could be purchased at the farm Coop. Chemicals packaged for agriculture use are vastly cheaper than equivalent stuff for home use. (Roundup at 50% concentration is less than $25/gallon in bulk). I could mix several gallons of spray for him for only a few dollars. He sprayed, violets died, $$ was saved and all was well.
Now, this happy tale depended on someone being able to read a MSDS sheet, determining the active ingredient(s), reading the product labels at the Coop to determine an equivalent product, and reading and understanding the product instructions to determine how to mix an apply. The same steps would need to be reliably taken for an insecticide.
There aren't large numbers of approved insecticides, so it is likely that a farm store would have whatever it is that is being sprayed at your house, probably one of the organophosphates or pyrethins. That said, while I battle bugs in the crops, those that live in the house are tolerated so long as they are not doing obvious harm. So far, although we live in buggy TN, the only insects that have invaded the house in numbers to trigger a response have been ants. Borax takes care of them.
>Wow, thank all of you for your responses. Pretty much sums up my thoughts as well. So I think I can do just as well as my bug guy for about 1/4 the cost. His excuse for raising his prices 20% was the cost of gasoline. Also, this is not his first increase. He's a nice guy (independant) and I've had him for several years and the job he did was ok. But I explained to him that the cost of living is increasing for all of us at an alarming rate and I just have to cut back.
I already have a pressure sprayer and a mask respirator with the proper filters so it will only cost me for the chemicals, and 20 min of my time once a month or every other month. A couple of product names were mentioned and I appreciate that. Thanks again, John
>BTW, GLY-4 has the same active ingredient as Roundup (glyphosate) and is usually much cheaper. It was 1/2 the price the last time I bought a jug of concentrate at the local farmer's co-op.
>Just purchased 2.5 gal. of GlyStar(?) 41% glosphate(sp?) from large chemical supply, $80.60 and is going up another 20 bucks soon. If you need some, best get it now!
>At least for us in TN. My pest guy is honest. He's a local fella and a no BS kind of guy. We only have a termite contract with him. We have had termites in the house several times. He says that he can't stop them from coming in and that what we pay him for is insurance to cover any damage. We've had no damage, only swarms, and he has done everything he can to combat them. Eventually, he switched to a new chemical and we paid him to start us over with the new stuff (can't think of the name - Termidor?). No termites for a couple of seasons - not even in the yard ( I used to see them every time I dug in my garden). Now, April is termite month here, so I hope the trend continues! Time for the termite commercials on tv to start running to panic everybody!
I have ordered stuff from the diy pest control site and had goodluck with them with help and good service/product. I didn't know this, but you can order Termidor. I applied it myself in a couple of areas before he retreated.
