Makita 1/4 sheet pad sanders
Bill Hammond, Oregon Coast
>I asked for advice on which pad sander was the best. Makita was recommended by many. How is the dust pickup on the Makita? The port seems smaller than most of the others and the one on display at the local ACE has no dust catcher attached so I can't tell if you can easily attach a vac to it without buying another attachment thing.
Bill, who at the moment is thinking Gaffers Tape.
Re: Makita 1/4 sheet pad sanders
Scott in Montana
>While I haven't used any major manufacturer's 1/4 sheet for a number of years, I may be wrong, but I would think that it would be equal to the others. My Fein sander is better, and I'm willing to wager that the Festool is as well.
Both of my Makita sanders have dust ports and after purchasing a rubber hose adapter, I was set to go.
Scott
Jay St. Peter - SoMD
>Fein sells a step adapter that'll probably help. Look it up on Amazon as an accessory to their vacs.
Jay
Howard Acheson
>My 1/4 sheet Makita sander has its own dust bag. It works just fine. The connection port is rectanglular so, if you want to hook it to a remove vacuum, you would need to fine a compatable connection.
BTW, its one of the best power tools I have. It's probably 20 years old and still going strong.
The factory dust bag works perfectly
Howard In Toronto
>You just need to open it up and shake it out very often.
HTH
Howard
