stacked dado
woodenleg
>Is there a proper order for putting the inner blades in the stack? One of the kids that I work with asked, I didn't know. Thanks Dave
stacked dado
woodenleg
Re: stacked dado
>Good Afternoon Dave,
I think the most important consideration in setting up a dado head is to keep the teeth arrayed in two or more of the dado/chippers from contacting. I do this by making sure my first chipper's tooth bisects a gullet of the first dado on the arbor. My second chipper is situated 90 degrees from the first chipper. As subsequent chippers are added, I try to keep them balanced with respect to those previously installed. The final dado blade on the
arbor is placed so as to have the teeth on the last chipper bisect a the gullet of the final blade. It is crucial to keep the sides of the blades and chippers FLAT against each other, and blade tips not in contact with one another. Otherwise, things go South quickly.
George
Re: stacked dado
>I think George nailed it. I have an old steel set (not carbide) and the teeth are set. I find the chippers will "nest" in between the the teeth and does best if set ahead of one that is set "outward". I spiral the chippers around and be sure the last one nests also. As an aside, be sure the teeth all point forward. My high school shop teacher put the chippers in backwards. You should have seen the smoke.
