OT - GPS (not navigation!)
Doug Ring
>Here's a question for you hikers. My other hobby is go-kart racing, and we lay out our tracks on large parking lots. Duplicating a track layout is tricky, as we are not supposed to paint dots on the pavement.
I would like to know if anyone has experience with any hand-held GPS units that have good resolution down to, say, 2 meters. I would like to be able to hit the parking lot the night before and mark "strategic" points with chalk to assist layout in the morning.
TIA,
Doug in San Diego
Re: OT - GPS (not navigation!)
Henry Higginbotham
>I understand the problem with paint, of course, but have you checked to see if a few p-k nails (or similar) would be acceptable? Surveyors leave them in asphalt parking lots all the time, and probably nobody would ever know it if they didn't paint around them with fluorescent orange paint.
I doubt you're going to find a GPS receiver that really suits your needs for anything near what you probably want to pay. I used a Garmin GPS-V with WAAS for mapping hiking trails for several years, and while the repeatability looked excellent in the context of a 12-mile section of trail, in reality it could vary 30-40 feet from one traversal to the next. In an open parking lot the accuracy would be better overall, but still . . . .
>The last I checked, the best accuracy with a GPS is 9 meters, but this is only if the unit has WASS (not all do, or at least, not all did.)
The accuracy also depends on the geometric configuration of the satellites in sight at the moment as well as signal strengths. The first you have no control over except to wait a while. The second may be improved by some small amount by mounting a good external antenna on a pole.
There is a method that does a trick with multiple GPS units to give accuracy to just a few centimeters. I last read about it in reference to autonomous robotic airborne vehicles about 10 years ago. It was very expensive. Someone did propose to build this type of system into a walking cane for use by the blind but that may have been a wild dream.
I've seen GPS surveying equipment available for rent. I don't know the accuracy but you might check.
Something else which would work better for your use is a surveyor's system which uses a laser from a fixed location and a pole with retro-reflectors. The system can pinpoint the location of the pole with extreme precision. I was told these were pretty expensive to buy (around $30K?) but were available to rent.
Differential GPS
Mike Fitterling
>Look for "differential GPS." The Cayman Islands Department of Environment used that when I lived there to position marine parks and mooring buouys.
However, I think any GPS can plot very accurately relative to a starting point. It may not be to the meter as far as earth coordinates but should be that accurate in distance and bearing to and from waypoints.
Philip F Duffy
>Having run the GPS program when stationed in the Pentagon and having been the first operational commander to use it in the field - -for minesweepers to find, locate and "remove mines", I will tell you simply that the system is far more accurate than the hand held units most of us use. My own can be incredible, to a couple feet at times, but then there are locations where I cannot find a city block! The interference, weather, physical obstructions, natural or otherwise, and battery power, all can lead to serious degradation of the plot. Over time and with new algorithms in the hand-held units will lead to better accuracy. Personally, I would not stake my life on a GPS-only plot of my navigation problems. At sea, the units are superb, provided the batteries are up to the challenge! By the way, most units will not accept rechargable batteries. Philip
