French Walnut
Howard in Bethesda
>Will French walnut lighten with time the same way American walnut does?
Thanks
Howard
French Walnut
Howard in Bethesda
Thanks
Howard
Re: French Walnut
Robin Corell in Atascadero, CA
>French walnut dosen't have much color to begin with, compared to american walnut. By american walnut I am assuming you mean juglans nigra as oposed to one of the almost 20 different species native to North America. It has been my experiance that claro walnut(juglans hindsi) holds its color significantly better then juglans nigra.
Robin
Re: French Walnut
Sgian Dubh
> "Will French walnut lighten with time the same way American walnut does?"
Yes, but I rather disagree with Robin's general observation that Juglans regia lacks colour. The shades and tones of browns mostly, with some pink and a hint of purple tend to be a bit more subtle perhaps, and there is often a grey background.
Like Juglans nigra the American black walnut, it can look a bit cold and uninviting if all that's applied is a clear finish, especially water based finishes which generally lack warmth. Both usually benefit from something used to warm the tones up a bit prior to applying the clear final coats. Boiled linseed oil applied as a first coat or a light dye made of brown, red and yellow base colours for example both help to make walnuts more warm and inviting. Slainte.
