THE WOODRAT IS BACK!
Plywood VS the dovetail.
ken raddon
>I bought that dovetail jig I was asking about on here the other day.
Now I have some questions. Can you use dovetail joints and plywood? I was playing with my new tool and the plywood gets all chipped up. I tried using a back up board (Like I see in videos) and that helped a little but it still gets chipped.
Any suggestions?
Ken Raddon.
Re: Plywood VS the dovetail.
>Try baltic birch, it's less likely to chip.
Clint
>Good Evening Ken,
Early on in my Master bedroom project, I thought I'd use plywood for drawer boxes, to be faced with solid cherry. I bought birch ply from a dealer weho supplies my #3 son's business. It wasn't "Baltic" birch, but premium domestic stuff with no voids. It looked good but performed poorly. Even using a backer board, the chip out was more than I could live with, and I wound up trashing all the drawer stock I had cut for my hiboy. I reverted to poplar and white oak for my drawers. It wasn't really more expensive and my dough went to domestic businesses rather than abroad. Besides, I had all the fun of resawing 6/4 stock and planing it down to the 1/2" thickness. A little extra time spent, I admit. But that is why I have all those tools in the shop to use in retirement.
George
Dick Coers
>I've never had any luck with plywood and dovetails. I've tried climb cutting and using backers, never like it. Soft maple is my wood of choice for drawers. With the quality continuing to drop on plywood (warping, thin veneer, poor gluing, I may have to stop using it all together!
Peter Gregory
>Strangely enough, cutting them by hand would likely work well. Your problem is the router bit is pulling apart the plywood and that isn't going to change.
David Yoho
>Ken, you would save yourself much grief by forgetting the dovetails in plywood. I've even used premium Baltic Birch that chipped badly. You would be better off either using a different joint with the plywood or using solid wood for your drawers.
David
ken raddon
>Thanks, I agree. Although I am only making a box to hold my fishing spools and reels I will go with a rabbit groove type joint. Or is that a dado? Can you tell how green I am?
Ken Raddon.
I don't get it - I've had great success...
Tim Greif - West of Chicago
>I have a Hartville 12" jig (same as a PC 4112) that I use for half blind dovetails. I've done a number of drawers in Baltic Birch and have had great results. I don't understand the chipout issue, at least for half blind dovetails.
When you cut them on a jig like this, you machine both the pins and tails at the same time, with the pin piece acting as a backer for the tail piece. Yes, you get some chipout on the tails, but only on the inside of the tails, which get buried and hidden inside the pin slots. Since the exposed portion of the tail is backed up by the pin piece when routing, it doesn't chip out, at least that's my experience. Now I can see how full dovetails would be a problem, but not half-blinds.
Am I missing something?
Re: I don't get it - I've had great success...
Carol - now in NC Nebraska
>You are not missing a thing, Tim. That is my experience as well.
To minimize chipping in either ply or solid wood, score the cross grain with the very corners of the dovetail bit in a light pass across the entire piece before hogging out the rest of the waste. Once those cross grain fibers are cut, chipping is drastically reduced, if not entirely eliminated.
This works very well with half-blind dovetails. For through dovetails, use a backer board on the back side of the cut and light scoring on the front side.
Quality materials with good technique will give you great results.
Gary Smyth
>If you took the time to buy the jig and learn how to use it why would you use plywood for the sides? To be sure it will take a lot to tear a drawer apart but if you do use plywood for dovetailing it in no insignificant measure loses the strength of the plyood. Yes, plywood is a stable material, but any normal decently milled and fitted drawer will not be a problem using solid wood even to a 12" wide and 24" long drawer.
If your building for the shop then the tearout can be limited by scoring in advance (and no void Baltic Birch). But for display then I'd favor solid wood.
My Experience...
David Yoho
>I've cut half blind dovetails in BB plywood before with my PC-4112. While they turned out okay, they didn't fit together without some real persuasion. The same setup on solid wood yielded joints that went together with ease. I just don't have the time or patience to trim all the plywood joints to fit right after taking them out of the dovetail jig.
David
Jerryburns
>I just finished my new kitchen cabinets all the draw boxes are 1/2"
maple plywood with dovetail cut on an old pc4112 jig I used a 14deg whitside bit scored the inside face first and had no splitting plywood came from Manards it was stamped a product of Canada I know cheap inport stuff.ps is full 1/2"
