OT - computer woes
OT - computer woes
OT - computer woes
Carol - now in NC Nebraska
>My computer has been done for a couple of weeks. Came up with the blue screen. Was in a local shop. Diagnosis was registry problems. Finally got it back but it locked up three times the first night. This is the second time in 4 months I've gone through this.
And he says, "If 'system restore' had been on, this would have been easier to fix." I don't even know what that is! If he didn't turn 'system restore' on the first time he fixed it, then my suspicious nature gets activated about his ability to properly repair, or intentional 'job security' built into his repairs.
So I don't want to spend anymore money with these guys.
Is there a book or something out there that would be helpful? I am willing to download all my document files, reformat the c: drive, reinstall the operating system, hassle all the drivers, etc. if I have to. But I would like to learn something about the health and maintenance of the registry.
What resources can you all recommend?
Re: OT - computer woes
Buy a Mac
Dustmaker Mike
>Ok I had to say that because they do not have these type problems. But with that said. The register is a large cumbersome MS thing. It can be edited very simply but if you get it wrong it will give you the Blue Screen you described. So what do I do to take care of my register, I use a Regedit program I downloaded from Cnet. I am not sure which one it is, I am at work and it is at home. It does a good job of cleaning up the register and keeping track of what is what. I started to use it right after I reloaded the system so it had a good solid start. I am not sure how well it will do with a system that has been running awhile but I think it will work just fine. When I get home I will look at the name for you if you like.
Re: Buy a Mac
>Please, and thanks, Mike.
Bill Howatt
>Go to Help and Support and lookup System Restore. It basically takes a snapshot of your system at certain times and before you install new software so if a problem is caused it can "roll" your system back to the previous state.
If you haven't installed anything new and are having freeze-ups and weird things it might be a good idea to run a memory diagnostic. A bad memory (RAM)location can cause all sorts of weird things to happen. A good free one is Memtest86+ available from www.memtest.org Note the .org not .com.
You can also run chkdsk to ensure your disk is in good shape as well.
Another often mentioned cause can be virues - are you running updated anti-virus software? I will say that my experience indicates the problem is often attributed to viruses but the cause is frequently soemthing other than a virus.
Bill
Re: the Registry
Chuck W
>Carol,
Its been my experience that once a registry get messed up then the best thing to do is a complete reinstall of the OS and other programs. That said it would be ideal for you to save all documents and important data to a safe place, and prepare before hand all the cd's, serial numbers and diskettes needed for the re-installation process. Is your current drive partitioned? If yes then only the C:\ portion will need formatting. XP has this feature built in. Just follow the on screen instructions after booting from the XP cd. It should go fairly smoothly. You may need the motherboard driver cd. Let us know how is works out.
? re: re-installing OS
>This machine is nearly 4 years old. I was prepared to buy another computer if I had to, but the techie said the hardware was fine. He could have made a sale and he knew it, but maybe he didn't. Maybe he didn't know it after all...
Anywho. There have been several Windows updates, including SP2. If I have to re-install the OS, then I would have to all also re-download all those updates. Yes?
Just trying to get all my ducks in a row before pulling the trigger on any action!
Here it is *LINK*
Dustmaker Mike
>Registry Mechanic is the one I see on this computer. So that must bbe the one I use. Hope This Helps
Registry Mechanic
Re: SP2 and updates
Chuck W
>Carol,
SP2 can be downloaded in its entirety and burned to CD and is available on the MS website. Just go to the downloads section and look for XP SP2. The file size is in the region of 190-200MB so if you don't have a highspeed connection this may not be an option. I think you can also order it for a small fee. SP3 is not released yet.
What you need to reinstall the OS.
1)First back up all important data to a safe place
2)XP CD and serial number
3)XP SP2 on CD if obtainable
4 Driver disk for the motherboard.
5)Driver disks for any other hardware you have
6) Any other programs you want to reinstall
You may need to set the boot order in the BIOS to boot from the CD.
I don't think I have forgotten anything.
I hope the reinstall goes smoothly.
Re: Device manager
Chuck W
>I forgot to mention to have a look in the device manager. There should be no yellow marks against any of the devices and no device conflicts either.
Eddie Pacheco; San Jose, Ca.
>Hey Carol, We had a major problem with my PC last year when it got a nasty virus. Nancy got some free online help and we/they fixed my PC over the course of a few days. All via the internet. I just tried to find any e-mail from this group, but I remember now that we used Nancy's e-mail id. She's in Israel on business right now and I'll get a hold of her later in the evening. It's a group of volunteers that provides this service.
Re: OT - computer woes - MY two cents
North of the Border
>If your computer is 4 years old, my advice is better spend money on a new (much better and faster) machine. Prices for computers have gone down over the years and for the same amount (or less) of what you paid 4 years ago for your current problematic computer, you'd be able to get a far superior one. The dual core board and Vista are pretty the standard thing and whoever told you your hardware is still 'good' may be right, but good is not good enough when PC technology has improved so much in the past two years or so. I'd think a new desktop wouldn't cost you anything over $350 these days (assuming you have other accessories like the flat monitor, etc.). How much did you spend last time on your repairs? $80? You were right when you said you wouldn't want to spend more money on those guys. Keep your old computer as a back up if you want or simply donate it (just make sure you wipe clean with a program (which is much more than just deleting the files) your harddisk before handing it over to a stranger).
Jesse Cloud
>You know Carol, you could do a lot of woodworking in the amount of time its gonna take to reload XP on your computer. And the woodworking would be a lot more fun!!
If you do get a new one, be sure it has XP and not Vista. I'm getting closer and closer to pulling the trigger on a Mac, the whole pc mess is just not worth it - life is too short, no?
PC pay my bills but a MAC
Dustmaker Mike
>will my computer of choose in a few years. Right now I have to stay with the Mighty Fine virus called Micro Soft. But when I get out of this job I am buying a MAC and not looking back.
