Steel City mortising machine
Joe in a Cleveland suburb
>Anybody have the subject mortising machine? Any comments?
I'm in the market and was looking online at this particular make.
Thanks.
Joe
Re: Steel City mortising machine
Pete in Holland, MI
>Purchased one a couple weeks ago. Machine assembled well and is pretty impressive. Several things pointed me to the SC over the Delta and Jet. Had some problems with the 3/8 & 1/2" chisels that came along with it. Wouldn't clear the chips for the first 3/8" of the drill. Called SC and 2 replacment chisels arrived 3 days later (yesterday).
Building some tables this weekend with a lot of mortises needed. Will have a better report on Monday.
Asking around on this site, it seems to be a common problem that many of the bench top mortisers have is that the "free" tooling is not great quality.
Pete
Think of the chisel ass'y as a kit
Neal in San Jose
>There have been several how-to postings about these hollow chisel sets lately. I don't know why the manufacturers don't make them usable out of the box like router cutters or table saw blades, but they don't. Bottom line, pick up a set of rubberized abrasive wheels and points (do an eBay search on Cratex, they are sort of the Kleenex of rubberized abrasives) for about $10 plus shipping, and wind up your Dremel. Use the points and wheels to polish the auger, and polish the inside of the chisel with sand paper wrapped around a dowel. Make the chisel as sharp as you know how; you have a 2 inch cutting edge on a 1/2 inch chisel. With a sharp, well tuned chisel, this machine will change the way you do woodworking! HTH Neal
Re: Think of the chisel ass'y as a kit
Pete in Holland, MI
>Neil -
I have been learning that these chisels do need some attention right out of the box. I can see if the companies want to save some money and give a lesser finish, but it would be very helpfull if they sent instructions on how to tune up the set, or give you an option on a set of chisels that WILL work right out of the box.
I did take a couple chisel sets from my JET drill press mortising kit and they worked fine in the SC machine, other than I needed to cut some off the tail of the drill to make it fit.
