Will a Jet riser block fit a Rigid bandsaw?
Glen
>I have a 14 inch Rigid bandsaw and would like to get a 6 inch riser block for it. Unfortunately, Rigid charges around $160, which is almost a third the price of the saw. I read online that Jet's riser block, which costs $75 at Rockler, is an exact fit. Does anyone know if this is true?
Thanks for any help.
Glen
Re: Will a Jet riser block fit a Rigid bandsaw?
>Good Evening Glen,
Call the technical people at Rockler and ask. They may know.
George
Stuart Hough
>Glen,
You can make almostanything fit anything with some patience and precise work. I put a Jet riser kit on an old Buffalo tools 14" band saw. I had to be VERY careful about how I lined the components up. i used bluing dabbed on the locator pins to mark where to drill the holes to receive the pins. the original unit had roll-pins inserted through a drilled hole that ran through the top arm and base at an angle. When I got the holes drilled on the top arm, I tapped them to receive #10 machine screws, which I then threaded into the holes and snipped off the heads. With a little filing I had new locator pins , and the best thing is that somehow I messed up and did the modification perfectly right...the first time! After that it was just "follow the instructions" and I was the proud owner of a bandsaw with 12" of resaw capacity! ( I know, I know...real men don't need no stinkin' instructions ) Best thing is, I have NO safety issues, and it will look "factory" once I paint it all one color. Good Luck! Hope this helps.
Gary Evans Tallassee, TN
>Glen,
Another option is to make one from scratch. I used 1" square tubing welded into a rectangle and inserted hickory in the corners where the locating pins go. The only thing I would do different would be to use hexagonal stock for the upper guide post. I used round stock and it takes just an extra few seconds to make sure the guides are aligned properly after you move them. I think I paid $8 for the longer bolt. Everything else, I had on hand.
Like Stuart said, the alignment of the pins is the only tricky part.
Just ignore the dust in the photo. Obviously, I don't let my saw stay like that all the time. 8^]
Gary
>Just wanted to note this is an early pic. I have since added a rear blade guard out of walnut using the brackets from the original. I haven't seen any need for the longer front guard that you get with the kit. There doesn't seem much likelihood that I'll have my fingers in that area when the saw is on.
Gary
An even better deal, if it fits *LINK*
Andy in Raleigh
>Grizzly is closing these out for $32.50 (around $40 shipped). I am fortunate enough to have a saw it will fit.
G1127 6" Extension Block Kit for G1019
Steven Mellott
>Amazon also sells the Jet riser block kit. In their customer reviews, several buyers talk about their attempts to use the Jet kit on the Ridgid saw. Some say it worked great. Others say it didn't work at all. I know this doesn't answer your question, but thought you might be interested in their comments.
Re: An even better deal, if it fits
Steven Mellott
>Does anyone know if the Grizzly kit will fit a 14" Jet bandsaw?
Andy in Raleigh
>You can download the PDF install instructions and get a pretty good idea. Looking at pictures, the alignment pins on the block appear to be the same, but that's just eyeballed. If they aren't, then drilling them would be easy. I think the major issues are whether or not the guidepost and guards fit. Another minor issue is that they give you a long bolt but not the nut, so if your existing one is a different size or threading, you would have to get a nut or different long bolt, which is not a big deal.
