OT PVC fitting removal
tom norton
>I need to remove a 1 1/2" bushing from a 2" fitting. How is it done?
tom norton
Hacksaw
John E in SC
>Not trying to be a smart aleck, but if it's been cemented together, I don't think you'll be able to get it out. Only solution would be to cut it off and replace. PVC glue actually "welds" the parts together.
John
Re: OT PVC fitting removal.. there is a tool...
Gary Camp, Bend, Oregon
>If I am correct, you want to remove a bushing thar has already been glued in place. There is a tool called a ram bit (or something like that, mine is at work and I am not) that uses a cutter sized to fit certain pipe sizes. Different guide washers allow for different pipe schedules. A couple of years ago we were doing a remodel at work and the plumbers loaned me one. I went out the next day and bought 3 sizes. It is a tool that no building maintenance guy should be without. It has saved me way more money than the orignal cost, about 20 bucks. I have only seen them at commercial plumbing wholesale houses. I'm not sure, it may be a trade secret that I was shown by mistake, I hope the guy that showed me didn't get drummed out of the guild.
glc
Re: OT PVC fitting removal.. there is a tool... *LINK*
>I never heard of this, but from what I found it sounds like it removes the pipe from the fitting, not the other way around.
To remove a glued fitting I've always cut the pipe back and put in a new short section with a coupler. This is difficult if the pipe is coming out of a block wall and it's not quite long enough!
ram bit
Large hammer
>Hi John, I read it as he wanted to remove a 1-1/2"bushing from inside a 2" fitting. The Ram Bit does that at a reasonable cost. Much cheaper than some of the other tools shown, although they look like they would do an excelent job. I agree about cutting off pipe and the difficulty that a block wall can present. I wish I didn'r know about that from experience. How are your horses doing? Our coming 3 filly has been at the trainers for about 6 weeks and Lisa got to ride her 2 weeks ago
glc
I knew I should have asked this question
Lee Schierer - McKean, PA
>On Saturday my son in law asked me a similar question for a fitting in his house. I thought about posting it here, but didn't. I'm not sure he would have saved much over the plumber, but it is good to know there is a tool to remove pipe from fittings.
Lee
>Yes, I missed the "bushing" word!
The horses are fine. I've been riding the mare an hour or so every day that it's not pouring rain or zero degrees. I have access to 150 acres I can reach from the barn without having to trailer or even get on the pavement which simplifies things a great deal. The terrain varies from steep hills to flat fields, old logging roads, tight woods trails, etc.
(Oregon, eh? I'll bet you live in "big country" with 100s of square miles next door!)
Since my other horse is blind, I've been looking for a second trail horse so two can ride, preferably another gaited horse, Fox Trotter or Walker. I looked at a nice 5-yr TN Walker gelding a few days ago. He was incredibly smooth and has a lot of spunk but has a couple of serious training issues. For one thing, he would not stand still for mounting! The first time I tried to get in the saddle, just as I swung my leg over he moved forward and away from me (even with the owner holding him) and I ended up on my back, the back of my head smacked on the ground, and rolling away like crazy to get away from his feet! I'm glad it was soft pasture rather than the gravel lane. The owner said "don't worry, he only does that the first time I get on him each day." Yikes! I may still make an offer on him since I think I can train him to stand still. (Took me months but finally my mare will keep her feet perfectly still for mounting and won't move until I'M ready.)
I found a local guy trucking in very good timothy/orchard hay from Canada, $7/bale, several dollars cheaper than anyone else around here.
