I suggest you run type L or K copper pipe
Grant Smith
>Copper pipe is rated for compressed air, and if it leaks, it isn't likely to fail catastrophically like PVC may.
You can get fittings to convert sweat copper fittings to the 1/4" or 3/8" pipe thread you'll want for your compressor fittings.
Do some research on the internet on the subject, and you'll likely find more info about the following tips:
-How to "sweat" copper fittings..it is easier than you might think
-install some slope or pitch to your lines to direct condensate to where it can be drained off and won't collect into the quick release fittings. Install drops so the "T's" point upwards from the main run, then two elbows to turn it back downwards so water doesn't flow into the drop. Install a "drop leg" near the copressor on your line system with a valve to drain off condensate that gathers in the lines.
-use a flexible hose and a ball valve between your compressor and line system so you can isolate the two when you leave the shop...this will prevent minor leaks from bleeding down your air reservoir while you are away. ALWAYS turn off the compressor when you are away...a burst line WILL burn up your compressor if it goes unnoticed.
-For longer runs, consider larger diameter line, such as 3/4". This will keep airlow and available pressure to a maximum. It also increases stored air volume, which means you have more reserve for sprayers, air tools, etc.
-Go to a local industrial tool supplier for your coupler fittings. These will be of higher quality and therefore less likely to leak than homecenter grade fittings. Since there are a few different types of fittings, check with any friends whom you may want to share tools with to find out which types they use so you can interchange.
FWIW,
Grant in Iowa
