Padding Shellac
Padding Shellac
Padding Shellac
Howard M
>I want to try padding shellac tomorrow and the books say to use padding cloth or trace cloth. If I go to a fabric store what is the closest cloth I should ask for?
Thanks
Howard
Re: Padding Shellac
Re: Padding Shellac
Glenn Madsen, near San Francisco
>I don't know what either of those materials are.
I've always used well-washed old t-shirting scraps, or cloth diapers that have gone well past their original intended use. Depending on the size of the project, I sometimes pass on the wadding in the middle of the pad, if the project is small, and the surface of modest size. For a dining table top, I'd get something for that. Wool comes to mind.
Best of luck with your material search, and your project.
Re: Padding Shellac
Re: Padding Shellac
cfreeze
>I also use old t-shirt material for padding shellac, as well as my now 6-year old's old burpcloths. For the wadding inside, I usually use an old white athletic sock all rolled up. Hey, it works for me. :)
Re: Padding Shellac
Trace cloth
Michael Dresdner
>Trace cloth, called padding cloth because it works so well for that job, is a very tight weave all cotton cheesecloth. You can buy trace cloth from many of the woodworking specialty stores that stock H. Behlen products, or from Mohawk. The closest thing to it is 100% white cotton cloth with no nap and no sizing. That means you will most likely have to wash whatever you buy at a fabric store before using it.
For what it is worth, I find fine weave linen even better for the outer wrap of a pad. It really allows you to get a high shine quickly. The inside can be cheesecloth or any cotton material.
