Epoxy Fills - Turning
Steven Reznek
>I want to turn a grove, say 3/16" wide and and 1/4" deep and fill it with an epoxy. The epoxy will be filled with a pigment and maybe saw dust. I am having a great deal of difficulty with bubbles. I am using slow cure, but I am not getting the bubbles out. Does anyone have an easy way to get the bubbles out? Does anyone have a hard way?
I have heard about using a heat gun, but that has not bee too good. Can you cut the epoxy with acetone to lower the viscosity?
I have seen Moultrop's stuff. What does he do? Can you use something other than epoxy?
Re: Epoxy Fills - Turning
Pete in Holland, MI
>A lot of your bubbles are being generated while you mix the epoxy. A vacuum chamber will suck all the gasses out of the mix before you pour, but don't stir it up afterwards, else you'll need to start all over.
Re: Epoxy Fills - Turning *LINK*
Phil Joines Krum, Tx
>There are a couple of ways to deal with bubbles. Use a thinner and slower curing epoxy or try polyester resin. The slower cure gives the bubbles longer to work their way out. Check your filler material for reactions with the epoxy. Sometimes stuff like brass will cause problems. Do a test piece with the same materials.
If you have a vacuum pump set up a vacuum chamber. Pull a hard vacuum right at first and let it set for 5 minutes or so. Them SLOWLY let it out. This should pull the bubbles to the surface. It you don't have a vac set up try pricking the bubbles with a pin shortly after doing the pour. If you still have some, and you probably will sand the surface to near the final size and fill any holes with CA glue.
There is a lot of information on this kind of thing on the IAP Casting and Stabilization forum.
http://www.penturners.org/forum/forum.asp?forum_id=46
Scott Banbury
>My approach to bubbles in epoxy, depending on situation, are:
Seal the area to be filled first with a thin coat of brushed on epoxy.
Make sure the wood being filled is warmer than the temperature in the shop.
Slow setting epoxy and heat gun vigilance. I either use my heat gun on the low fan setting or a propane pen torch. The torch really works better. You don't want to heat the epoxy--that speeds up it's reaction and might cause more bubbles or fillers to separate. What you want to do is very briefly flash the surface above the bubbles to coax them to the surface.
Use the surface tension of the epoxy or build dams out of masking tape to get the epoxy to set an 1/8 proud of the final surface. This gives the last escaping bubbles somewhere to go that will be removed later anyhow.
