Ductwork installation
NickB
>I got the 11 boxes from Oneida downstairs yesterday, so it should only take me an hour or two to get the cyclone and the ductwork installed, right? ;-)
Any installation tips anyone out there would care to offer? In particular, tips on the best way to cut pipe (I'm using snap lock pipe) would be appreciated.
Thanks,
Nick
Re: Ductwork installation
Jim McFall
>With snap lock pipe you cut it before you snap it into a full circle. measure and do not forget to add the length that goes inside the next pipe. It may be necessary to "clena up the snap in joint with a little screwdriver where the shears squeeze it together. That will make it easier to snap together. I think also that it would be wise to put the male end toward the cyclone.
If the pipes do not go together as far as you want or need them to, use a pair of needle nose plyers and first make a sideways twist to the right and then move the plyers to the right about 3/8 inch and make a sideways twist to the left. That will add additional crimping to the male end and allow it to fit a bit better.
good luck and have a few bandaids handy.
Jim
Re: Ductwork installation Tips
Stephen Roth
>In no specific order.
1. Definitely get help putting motor on top of the barrel.
2. Use sheet metal screws for the joint. No rivets. (Hard to change)
3. Do not use caulk at the joints (hard to adjust and messy ) Use a high quality tape from an HVAC dealer. Not Home Depot duct tape.
4. Do not try it all at once. Try one run, cap the end, and then try the machine. You will be so happy with the results, you will be motivated to finish the rest.
5. The snap lock is a bear to get to fit together, but after a lot of squeezing, sit will snap in and be fine. ("Trust the force.. Luke")
6. You can use strap wrenches to adjust the adjustable fittings. Without them, you just can get a grab on the over 4" pipes.
7. The unit is louder then they advertise... but I am very happy with it.
8. When slipping the fittings together, think about it as if water was traveling towards the motor and you wouldnt want it to leak. That will help you figure which is the female/male section.
9. Recycle the crazy Oneida packaging.
Good luck. It takes time, but is worth it.
andrew nistock
>Hi Nick,
Congrats on your new system. I am sure it will work well for you. As far as I am concerned first off read the manual and guide to assembly of the system over a few times. Get the DC mounted in the position where it will live allowing for the ductwork coming into the unit. Careful, they are heavy and pinched toes and fingers make for a long day. Once the dc is in place start with your runs of piping. Hopefully you won't have to make a lot of cuts and as the other guy stated make sure that the pipe is oriented so the male or crimped ends of the pipe point toward the unit. Less drag inside the pipe and less chance of plugging. A wrap of duct tape around the joints after you fix them with screws seals leaks which if unsealed can interfer with performance. I have found that double cut snips work really well to cut the pipe. good luck and happy woordworking. Andy
