Plywood issues ( staining, size stability )
Michael Weise
>I've recently used frame-and-panel construction to build a couple of storage chests. Making the panels from plywood has proved to be a learning experience that's left me with some questions.
I know that if I had panels from solid wood glue-up I'd have to accommodate size fluctuations due to moisture content changes over time. Is this also a consideration when using plywood? (I assume it's less of a problem, since plywood is 'more stable', right?)
My last project used red oak plywood. I hadn't appreciated how differently adjacent sections of the surface veneer would accept stain. Is there a way to compensate for this? I ended up replacing a panel because the first one showed a banding pattern that wasn't very attractive.
Re: Plywood issues ( staining, size stability )
NickB
>You don't need to accomodate movement for plywood panels. This is helpful when making cabinet doors with cope and stick router bits, as you can glue the panel in, substantially increasing the strength of the assembly.
On staining, I can't give you direct information (I do very little of it), but you may also find that the plywood stains differently than your solid wood components. Finishing experts here or, for example, at Jeff Jewitt's website will be able to give more detailed (and most certainly better) advice, but you might want to consider sealing the work (e.g., with Sealcoat) and staining selectively using pigment stain or glazes to even out things.
Hope this helps,
Nick
>One "trick" that I've used on plywood (and other woods) is to wipe it down with mineral spirits, paint thinner or naphta. This will often show how the material will accept oil-based stains (as well as some finishes).
