HVLP for sealing a deck?
Phileas
>Hi all,
Is there a sprayer suitable for sealing my deck that is also suitable for future woodworking projects?
Thanks,
Phileas
Phileas
>Hi all,
Thanks,
Phileas
Any of them
>...provided you aren't planning to seal your deck with something that is too thick or viscous for the HVLP unit you buy. I can't imagine that.
Ellis Walentine, Host
Re: Any of them *LINK*
Louie Lovas
>I have a mahogany deck that I've used Cabot's Australian Timber Oil to seal. I've just used a pump sprayer to apply the oil and then wiped off any excess with a rag wrapped around a broom. Works great. I have an HVLP sprayer that I use for fine furniture, but I would not consider using it for sealing a deck. I only spray low-viscosity finishes, frankly that generally means shellac. I would not want to put that oily deck sealer in my HVLP sprayer, I paid way too much for it and it's best use is for fine finishing.
Flinthill Furniture
Overkill
Lee Schierer - McKean, PA
>IMO An HVLP sprayer is sort of over kill for this project. Most people use a pump up garden type sprayer to apply the sealant on decks. It makes far less mist and mess. Unless of course you are trying to justify the purchase of an HVLP.
Lee
Re: HVLP for sealing a deck?------WebKitFormBounda
Phileas------WebKitFormBoundaryn4+XyuwAhtbz4j8t
>Thanks everyone. As always, you've been very helpful.
Phileas
Overkill? Maybe Not? Long. *LINK*
tek-Brunswick, Ohio
>I agree that it is overkill just to do the flat deck a tank sprayer works fine for that. I have lattice enclosing the bottom of my deck. There, of course, are plantings in front of the lattice. To redo them by hand I have to remove the lattice panels from the deck, seal them , let them dry and then reinstall them. That is a two day project. I can finish them in place with my HVLP Gun in a few hours. It would go even faster, except I have to maneuver around flowers and bushes to do it. I have a Wagner HVLP conversion gun from Gleem Paint. They use a regualr compressor and air hose. I can only compare it to my old craftsman conventional spray gun. I like it a lot and have sprayed Deck sealer, latex enamel paint, Nitrocellulose lacquer, Waterborne lacquer, and shellac with it. Though I have never used a turbine hvlp gun I have seen them in use and they do have a little less overspray than my conversion gun. If I used one everyday I would probably buy a turbine unit. Since I only use it occasionally and it does pretty much what I need it to do I will stick to my Wagner. Gleem has them for $129.00 A turbine gun and turbine will cost at least 4 times that for anything decent. I have no connection to Geem except for being a satisfied costumer.
Gleem Paint
