>I preparation for spring storms, I checked out my standby sump pump today...the one that drains out onto the low end of my yard where the water will flow to the street instead of the storm sewer line in the back yard. The 1-1/2" pipe runs 6' straight up the basement wall, exits the wall, then turns 90 degrees and runs about 25' to the yard where water will drain away from the house. There is a fall of about 8" in that 25', although the last 12' of so does lay flat on the ground.
Unfortunately, (or fortunately, since I found the problem before it caused me any serious harm), I soon had a several small weeps through the cement block. Short version...the PVC elbow had broken off just outside the wall and the water was just cycling from the crock out onto the surface right beside the house and was running back down through the gravel backfill into the wall and into the footer tile.
Not only had the PVC elbow broken, the actual pipe had broken completely in two spots, and there were longitudinal cracks in the pipe for as far as 4 feet.
The PVC is exposed to sunlight outside. It is also exposed to freezing. I did not think either of these would make the PVC brittle enough to break, but I am obviously wrong. I checked the pipe and found nothing plugging the pipe. The pipe was unsupported for several feet, but it also broke where it was laying on the ground. I do not think enough water would lay in the pipe to cause breaking by hydraulic action, but I could be wrong. Still, hydraulic action would not have caused the elbow to break since it was 12" above ground level.
What went wrong? I have to correct this quickly, and want to do it so that I don't have problems in the future. Suggestions?
>I've used PVC for irrigation and for watering a horse corral. The UV (light)exposure and the temperature extremes really did a number on the PVC. I remember one night having to shut off the automatic watering line and having to lug buckets of water up to the corral - not fun (why does it alway happen late at night?). I ended up burying the line and replacing the above ground stuff with something that was UV resistant.
You can get varieties of UV "resistant" PVC pipe. Other alternatives are to replace it with a non-PVC pipe or shield it from light.
>Joe, PVC is certainly subject to UV degredation and any pipe is subject to freezing.
You should switch to the ABS (black plastic) pipe outdoors in any area sunlight might impact the pipe.
Also, remember that you can not glue ABS to PVC. If you do not replace all of the pipe, make a mechanincal connection. Either Glue threaded fittings, one male one female of a type "like" that part of the pipe and screw them together, or use a Fernco or No Hub connection.
>Actually you can glue ABS to PVC using multi-purpose glue made for just this application. However I also recommend a Fernco connection since it allows for easy separation for future repairs and replacements.
>There may be a glue that will adhere ABS to PVC, but the common universal "glue" you buy at plumbing supply places and the borgs will glue PVC to PVC or ABS to ABS, but not one to the other. The reason is that the jin is actually a solvent weld. You apply the glue/solvent to both surfaces, they melt and flow toghether. Its seems to work if you glue one to the other, but not well and the jins iwll fail under mechanincal pressure/impact. This something I look for on home inspections.
>I agree this would not meet code for pressure joints. This is not a pressure joint, but a sump drainage. Not a problem. For pressure you wouldn't usually use ABS anyway.
