Table top glue up wisdom sought
Pete in Holland, MI
>Guys -
Building a couple end tables & a coffee table in the Mission style out of quarter sawn red oak. I have several planks that are currently at 8% moisture content. The planks are 6-8" wide.
In your experience, should these planks be ripped narrower, then re-glued together, flipping every other boards over, or will the quartersawn stay pretty flat if I leave them in their current widths? Table tops will be about 22" wide when done. I am planning on cleats to hold the top to the table frame & allow for expansion.
My thoughts are that the quartersaw will be the most stable cut from a board, and that I should be all right.
Your thoughts ?
