Egg removal (OT)
John D. Luke
>Anyone know of an easy way to remove dried egg from a vehicle without damaging the finish too much?
Egg removal (OT)
John D. Luke
Re: Egg removal (OT)
>Quickly with soap and water. The longer it stays on, the more damage it will do.
BTDT
Lee Gordon
>Use cold water. Hot water will cook the protein in the egg and make it much harder to remove.
ken raddon
>I don't think you can get water hot enough to cook the egg before it comes off. Use a brush or a white pad scrubbing pad. You can find pads at the borg stores. White wont even scratch glass.
With that said if you have whatever it is you polish your car with that should take it off too. Smear it on real heavy and rub it until it glazes over or gets the egg off. A good polish (notice I did not say wax) will get everything off the paint, i.e. egg, tar, even paint over spray if it is light enough.
Ken Raddon.
Stuart Hough
>What I did was to take a washcloth, soak it in warm water with Dawn dish soap, and let it sit on the spot for about 10 minutes. This was on top of my hood, after a 40 mile drive home in the sun. It dissolved much of the egg "matter" on the first try. I then hosed the spot down with cold water and repeated the process. On the second attempt it got almost all of the rest of what was left, and I was able to use Rain-X car wash detergent and a T-shirt to buff the spot and remove the last vestiges of the egg. The T-shirt was the perfect cloth to use to buff the area, and when I was finished washing the rest of the car, you couldn't notice there had ever been a problem. Good luck!
Eddie Pacheco; In Tucson for a few days
>Warm water and soap will take off the egg, but if this was an egg thrown at a car the shell damages the paint to the extent that the "scar" will be there fo ever. I had this happen and after having the car wet sanded, polished, and buffed the eigns of the egg impact are still faintly visible. I'm not a happy camper when I see this everytime I wash the car.
Mike Huber
>Don't forget to re-wax. Typically Dawn and other similar soaps will remove the wax from your vehicle
Mike
