WAY OT -front load laundry machines
Tom Sweeney - Coatesville, PA
>Sorry for the OT post, but I know there is a lot of varied knowledge here so here it goes:
Our stack top load washer & dryer needs to be replaced.
I'm trying to convince SWMBO that a front load is the way to go.
We found a Bosch NEXXT 500 combo for a real good price & I'm trying to get opinions on these or Bosch FL washers & Dryers in general. One thing we have heard is that there might be a problem with mold growing in the FL washers. Any other good brands that won't break the bank like LG or whirlpool, etc..? Are the FL machines all they are cracked up to be or is a TL OK? I read in CR that the top load machines don't clean well anymore because they just lowered the temps to meet new energy regulations. Any advice on this would be greatly appreciated as I have no clue about laundry machines.
Re: WAY OT -front load laundry machines
Virgil Johnson, Versailles KY
>We have had a Kenmore for nearly three years which is an OK machine. I'm a bit disappointed that I've had to have the service guy out twice. Once for a plug that came loose from the motor and once for a small item stuck in the pump. It cleans well and is quiet. I have not noticed a drop in the water bill. The warranty is about expire which makes me a bit nervous. No mold growth problems here but the longest it sits idle is 3 days.
Howard Acheson
>Probably the best place to get up-to-date info is from Consumer Reports. They did an article in the past few month, I believe.
Go to your local library, look in the back of the current issue. They have a running index to all articles in the past two years. Get the copy and make a copy of the article.
John Foster
>Frontload washing machines are one of the few machines that actually pay for themselves. 1) they clean with less detergent, which is expensive these days; 2) they use less water to clean 3) they spin more water out of the clothes, if you use an automatic dryer as opposed to a line or drying rack you will save energy costs. If you use a line or rack they will dry sooner.
Bruce, a MN Galoot
>We have a Whirlpool Duet washer that is wonderful. We've never had a problem. It's far more efficient and water conserving than our old top loader, and because the spin cycle is so good, the drying time is considerably reduced.
I haven't noticed any mold problem, but MN in the winter is very dry and very humid in the summer. It's easy enough for ME to use.
Bruce in MN
Dan Mitchell
>RE: Consumer Reports at the library, with many libraries (3 I've had cards to) you can also get full text of CR excluding the last 90 days on the library's online site. Look in their databases section.
We have a Kenmore FL which seems fine. In addition to using less water, the much higher spin cycle drives out more water, so you use less energy to dry.
Concerning Bosch appliances, for what it's worth, there was a relatively new Bosch dishwasher here when we moved in last year. Maybe 3 years old, and an expensive "ultra quiet" model. My 1st impression was it had really small hard to load racks, which I didn't like. Broke down twice in 3 months, the 1st time I fixed it, second time we replaced it with a Kitchen Aid. May not be generalizable to other Bosch appliances, but from working on/using this machine anyway, I'd say it had an needlessly complex and trouble prone design.
On the other hand, my Bosch compound slide miter saw seems OK...
Dan
One other thing about Kenmores *LINK*
Dan Mitchell
>Their appliances are made by a number of manufacturers, some of whom may be better than others for any given appliance type. Here's a web page that will tell you who made a given Kenmore appliance from the model #:
http://www.appliance411.com/parts/sears.shtml
Ditto Duets.
Rod Peterson -- Ormond Beach
>Have 'em, love 'em. My daughter also has a set.
I've never heard about mold, but I did read somewhere to leave the washer door cracked open when not in use, which we do.
I don't know about other people's water systems, but ours charges by large blocks, so a 10% or even 20% reduction (and I'm not even sure what kind of drop in consumption you could expect) in water use by the machine may not be enough to trigger a drop into the next lower bracket. Also, I installed the units when I was in the first stages of remodeling—I wasn't living in the house, just working there; the kitchen was completely gutted; the master bath was completely gutted. It's hard to establish a baseline that way.
You will absolutely love the semi-dry clothes as they come out of the dryer, because that will have a significant effect on your dryer use. Again, however, I couldn't baseline that, either.
I won't retell the story of the first running of the washer after I installed it.
Bought/installed the units in the summer of '03. Zero problems, zero service calls. Probably the most satisfying appliance expenditure in our lives. Tied for first, that is, with our Bosch dishwasher, if that helps.
Rod
I have the Frigidaire Affinity set
Nat Robison
>.....Bought at Lowe's for about $1400. They've been in service for about 15 months with no problems. The best thing is that if you're doing several loads in a row, the dryer load is always done by the time the next wash load is done.......since they come out the washer with more water wrung out.
The mold problems may stem from keeping the washer door shut right after a wash load. The machine seals airtight, unlike a top loader. I always keep the door open when not in use. I've had no probs with mold or smells.
Since the washer spins at a much higher speed than a top loader, they can "move" a bit, especially with a slightly unbalanced load. I stacked the dryer on top of the washer to put some weight on it. Again, no probs with movement or vibration.
Gerry Wittenberg
>We have been using a Fridgidaire front loader stacker set for the past two years and will not be buying another. I found that they don't get the clothes as clean as a top loader with agitator.
Gerry, wearing spotted shirts.
Not trying to be agitating . . .
steve mackay
>honest ! But, do these front load washers REALLY get the wood glue out of jeans ? Sorry, but thats 'bout my standard for such things. Kinda like low flush toilets.
Neptune cs Duets
>This is just my opinion, but here goes.......
Maytag, the once proud and famous washing machines from Iowa, were the one of the first to try to introduce the front loaders into mainstead North America. Seems this coincided with their move to designing and/or making them in Korea. They made the Neptune, which I believe, singlehandly sunk their company. It leaked, and it was the one with the big mold problem /recall..... really gave front loaders a bad name.... gave Maytag a bad name for the first time, in what 100 years? I think they've come out with a newer generation, but the damage to their reputation and to front loaders in general, was done. You heard about mold problems? You probably were hearing the Neptune horror stories.
Now on the other hand Whirlpool came out with their Duet series a little later. The complete opposite was true.
Like I said, it's my opinion. When I looked into it last year before replacing our old reliable Maytag top loaders, I found that there was an equal number of horror stories as there were happy stories about front loaders. Looking deeper I found that the front loader horror stories involved the Neptune and the happy stories involved the Duets.
We bought a pair of Whirlpool Duets (their top model) and are extremely happy with them.
Happy Woodworking!
Can't explain, but....
>I was VERY skeptical..... c'mon you know me... I'm skeptical about EVERYTHING.
But everyone said the same thing.... it's hard to udnerstand how, but they do wash clothes well.
I'll admit I've spent more time that I should watching my Whirlpool Duet front loader...... and I simply can't understand how it washes my clothes.... my jeans..... so thoroughly. It defies understanding.
Yes, they do wash clothes as well as our old top loader.
Happy Woodworking!
Earlier front loader
Ken Garlock, Collin County Texas
>Oh Mark, you youngster you. :-)
Westinghouse introduced the Westinghouse Laundromat front loader back around 1950, It was advertised as a "tumble washer" that was kind to your clothes. There was also a matching dryer.
I remember the early Westinghouse TV commercials on our family 12" TV. When we moved up to a 19" TV, we thought we were living high....
I also agree with the Duet comments. We bought ours when we moved into our new house in 2002. Like a Timex, it just keeps ticketing.
Happy saw dust,
Ken
>Thanks guys,
Very good advice & insight - Mark, you're right about the neptune a lot of the negative I read seemed to be about that model. I think we're going to bite the bullet on the Bosch -I sure do like my little lithion Ion drill driver they make so now I can have a matching laundry center ;-)
GolfSteve in Calgary
>Hi Tom,
Both my parents and I have the Bosch Nexxt series washer/driers. They work very well and I don't hesitate to recommend them (but read below). My cousin also sells appliances for a living, but he does not carry the Bosch line. He recommends the Duet series for people who "have" to have a front loader. His store is in a small town full of cheap Ukrainians so he does not sell many front loaders because you can buy four top loaders for the same price, and in fact a lot of the old Baba's are still hand washing/wringing/putting the clothes on the line to dry and don't need a machine at all.
Anyway, I'm very happy with the Bosch washer/dryer set (and with a 10 year old Bosch dishwasher which is wonderful).
The things to watch with the Bosch are:
1. Use soap designed for front loading high efficiency washers. If you have soft water only use half the amount of soap that the soap company recommends. If you use too much soap, or the wrong type of soap, you will get a "blocked drain" error. You might get this a few times when you first get the washer - the salesman said it was normal because the washer was getting "old soap residue" out of the clothes. I can believe it. This washer washes very well even when using only 1/4 of the amount of soap that my old washer did.
2. I would recommend putting the washer on a concrete floor. The washer does move around a bit during the spin cycle. A concrete floor provides a stable base to limit movement.
3. Do not push the washer right up against the side of the dryer. During the spin cycle the washer frame moves around a bit (and it's worse if your washer is on a wood floor). If the dryer is pushed right up against the washer, the washer movement can crack the plastic panel/door frame on the front of the dryer. This happened to my Mom's machine (which was on a wood floor). My machine (which is on concrete) had no problem. A friend of mine also has the Bosch washer/dryer. His are stacked on top of each other and he has had no problems.
Anyway, I can't say enough about how much I like the front loading machine. My old top loader/dryer combo used to chew up my clothes and fade the colours right away. Wear and tear on my clothes is MUCH reduced now, leading me to hold on to my old, unfashionable, clothes much longer than I should.
And when the TV is on the fritz you can put the couch in front of the washer, grab a bowl of popcorn, and the whole family can have an enjoyable night out watching the clothes being washed!
For you Duet owners..
Bri in Mtl
>Anyone find that there's always some soap suds remaining at the drain near the door bottom?
I'm now using the minimum(No.1 mark on the cup) Tide HE and always using the extra rinse but still have some soap suds remaining.
Clothes sure are clean though.
Jennifer@Indy.USA
>I just bought new W/D and did a lot of reading prior to. Front loaders do use less water and energy, however from what I understand they are best for larger clans. It would have taken me 10 years to recoup the energy savings for the thousand plus price tag. For just two of us it wasn't cost effective. I think you need special detergent too? The newer washers and dryers are so hi-tech now that you need a degree in rocket science to use them. Okay I'm exaggerating.
Hot, cold, Big load, small. Don't confuse the operator is what I was looking for :)
Jen
2nd that rec - read CR reviews
M. McNamee
>I have never been dissapointed in following any of their recommendations.
Chuck Kettler Greenwood IN
>After 6 years, two pumps and now a main bearing I put a bullet in my Frigidaire front load washer. The maintenance tech lives in my subdivision. He services front loaders : top loaders about 10:1. For the huge price difference in a top vs front load you can buy a lot of water.
Re: NOT for me
Larry Clinton At Frankfort (Central)., Indiana
>I just can't see the justification - at least in my area. Of course I am an empty nester (long time ago). As my wife and I are both senior citizens - we really don't have extremely greasy or dirty clothes. Our Top loader does a great job - even taking out all the hide glue. As a retired Engineer, I tend to stay away from the "newest" high tech designs. I know some of the repair statistics on washer dryer repairs as I worked for one of the largest producers of timers / controls for these units. I think the top load is far more economical for the average family. Unless you live in an area where water/sewage rates are extremely high and you have an enormous amount of washing, I don't believe you will ever see a savings. I feel certain - due to the complexities of the FL units that the (average) repair costs will be a lot higher over a 5 - 10 year life span. As to appliance brands, I purchased a Bosch dishwasher due to the comments on this board. I could not be more pleased. We have had the unit about a year and it performs perfectly, quieter, easier to load, and does a much better job cleaning than any we have owned. Don't know about the newer Washers as we are still using a Whirlpool that is over 10 years old without any problems or repairs. I might look at a Bosch when - if we need to replace our current antique.
Get another one soon... disposable clothes???
>If you want another top loader better buy one soon. They'll be all gone in no time due to various pressures. I've heard rumblings that they might not be able to make/sell them before long.
I grew up with stories (and experience) with Maytag washers that lasted 25 years.
When we got married and moved inot our first house, we bought a top of the line Maytag which came with a 10 year warranty and figured it would last us 25 years. 12 years later it broke and was too costly to repair). Now we go and look for top of the line appliances and they come with a ONE YEAR warranty... but you can upgrade the warranty to 3 or 4 years.
Sheeesh.......
With the way our electronics and appliances have become disposable, we'll be wearign disposable clothes pretty soon.
Happy Woodworking!
