Scrapbooking Workstation project completed
Cody Lewis in Las Vegas
>I recently completed this Scrapbooking Workstation for my wife's birthday present. This is really the first "real" project I've attempted to-date, and much of the courage to attempt it came from knowing I could come to this Messageboard if I were to get stuck. In fact, thank you all so much for the many questions you answered that helped me. You all helped me with:
� Wood choice
� How to properly do two-tone finishing (especially on cabinet doors)
� Edge banding � which I had never done
� Sanding questions
� Finishing questions � poly, shellac, etc � and how to apply
� Drawer slide installation � which I had never done
� Mask and/or respirator help � so I could quit killing all my brain cells with the poly fumes
I�m sure there are more, but at any rate, thank you all so much for the help. My wife LOVES this present. Before this, when she�d scrapbook, she would spend 20 min getting all the stuff out (and for anyone who�s ever seen that, you know when I say stuff, I mean A LOT of stuff), then she�d spend 20 min actually scrapbooking, then she�d spend 20 min putting all the stuff away. I felt bad because when I�m done for the day on my wood projects, I just come in and leave my stuff out, but she couldn�t do that since her scapbooking table was the kitchen table. Now when she�s done, she just closes the lid and it�s all hidden so I don�t have to look at it.
As you can see in the pictures (I�ll put a couple more in reply posts to this one), it�s a tabletop supported by a cabinet and drawer on each side. There�s a lid on 270* hinges that folds completely out of the way to the back side. The entire workstation is on wheels so she can wheel it to whatever room she desires.
The ply is maple (with maple edge banding, of course) stained with Minwax Red Mahogany. The cabinet face frame is poplar also stained with Minwax Red Mahogany. The lid, the drawer fronts, the rails & stiles for the cabinet doors, and the edging on the tabletop are all poplar stained with Minwax Cherry stain. The paneling is 1/4 inch maple ply stained with Minwax Red Mahogany. The hinges, wheels, and round knobs were purchased online from Rockler. The other hardware was purchased at local shops. All exposed surfaces were finished with 3 coats of oil-based poly (satin), except the tabletop which got 5 coats.
I had a blast doing this, even on the finishing, which took forever. Thanks again for the advice. Sorry for the long post.
Cody
Re: Scrapbooking Workstation project completed
2nd Picture - front view, lid open
3rd Picture - side view, lid open
Re: Very nice - you realize that this will en-
>courage her to do more scrapbooking, don't you? Now you'll have to make some fancy inlaid covers for the books :).
>Good Evening Cody,
Small wonder why your wife loves that gift so much! It is very nicely designed, crafted and finished. I think the dual color you imparted gives it an especial "zap". It is attractive to the eye. And the functionality you describe must make her eyes light up every timer she looks at it. Very nice job.
George
pocket-hole jig trouble on this project
>Just before starting this project I received the Kreg pocket-hole jig as a gift. I used it to make the face frames for the cabinets, and I was amazed at how handy it was. It was at that point that I decided to use pocket holes to attach the hardwood edges to the tabletop - rather than use a pneumatic brad nailer like usual. I was excited because it would allow me to attach it without even the small putty marks. In the end my excitement was a bit dampened because the pocket-hole screws seem to be just a touch too long, which causes them to nearly poke thru the surface of the hardwood and creates a "bubble". When it first happened, I thought I was screwing the screw in too tight, so I set the clutch on my drill to whimpy, but in the end, every time I tighted it down to snug in the pocket hole, the bubble formed, no matter how delicate I was with it. I followed the directions very carefully, so I know the 1-1/4 inch screw is what I was suppposed to be using. Seems to me like they should make a 1-1/8 inch screw so there's still tons of strength, but no bubbles. Anyone else have this experience? Anything I can do to fix it?
Cody
Re: pocket-hole jig trouble on this project
Rod Peterson -- Ormond Beach
>To fix the problem on this project, remove each of the offending screws. Grind off about 1/8" of the pointy end. Reinsert and draw it up tight. You've already formed the threads. The point is no longer needed.
In the future, the process probably isn't that much different—grind off the points of as many of the screws as necessary. Go ahead and install an unmodified screw in a hole, but don't seat it all the way. Then back it out, insert a shortened screw, draw it up tight, and move on to the next hole.
Rod
rarebear
>I think its great but what do you think about adding some kind of feet?
think it look better if it was off the floor..
Kind of looks chop off..
I got it, I'm looking at my computer desk and it has molding about 2 1/2' high and a profile at top :)
>Most Kreg drill bits have an adjustable collar on the bit to set for the depth of the hole. You can set the depth so the 1-1/4" screw will not quite poke through 3/4" material as you experienced and it will still work fine. I always assemble a test piece before drilling a bunch of holes. If the drill bit does not poke a hole quite through the wood you can drill the hole on through with 1/8" or so drill bit set up in another drill. This helps the screw to pull the wood together better. That is a nice job and nice idea on the table for your wife; I am sure she will reward you well for it. I imagine you scored a number of points with her. If you keep this up you'll have the neat experience of growing old together.
>Good Afternoon Cody,
I experienced much the same problem recently, after using the Kreg jig for several years. Repositioning the collar on the stepped drill bit solved the problem.
George
>Yes, I agree. I didn't think it would matter when I was building it, but I may come back with some additions - some type of base casing or trim. I'll just have to be careful I don't do anything that makes it unable to wheel around because that functionality is key.
>I used to be affraid to move the collar on my Kreg drill, but then I realized it's not all that critical. I think the "standard" set up is to set the base on a flat spot, like your work bench or TS and set the bit in it and set the collar to the top of the jig. Thus, if you change it, it's easy to reset it. So, move the collar 1/8" lower or closer to the point to "shorten" the screw an 1/8"
Or, if you only want to shorten one or two screws and don't want to change the basic setup, you can put washers under the collar to hold the bit up. A little tape will hold them in place momentarily.
