Re: Hotdog Compressor - Increasing Capacity
>You've got several issues to address, Steve.
First (foremost) is the pressure rating on your aux tank. You must make sure that it is rated the same as your compressor's current tank. Note there are two ratings; burst pressure and working pressure. Remember, as the tank fills and empties, the seams and joints expand and contract. The faster you use the air, the more rapid will be the expansion and contraction cycles. Those portable 5gal air tanks may be fine for taking some air along to fill a tire or run a brad nailer, but they are unlikely to be rated for handling the duty cycling of an active compressor. You will run a real risk of failure and serious injury if you try to cut corners on the tank. Compressed air is, actually stored energy. If that tank fails, it can happen very quickly and with no warning.
Second; you will need a drain port to purge the condensate that will accumulate in the tank in fairly short order. The resulting rust in a wet tank will shorten the life of your unit considerably.
Lastly be aware that your compressor is designed to perform on a given duty cycle. If you double or triple your storage capacity it means that your compressor will have to run 2 or 3 times as long to refill the new volume to the set pressure limit. The longer the pump runs, the more heat it generates and the more wear occurs. Overworking your pump that way will most likely shorten the life of your compressor, so figure that into your "cost-benefit" planning.
Good luck be careful.
mm
