super quality brushes
Charles Yawn
>Need some expert opinions on quality paint-type brushes. I want to purchase a few really, really good and super best quality brushes for those paint/varnish/shellac/oil application jobs where the most important analysis is that mistakes cannot be blamed on the brush. Rocker has a sale on "Badger" natural bristle brushes. Are there better brand names or types? If you have input on the style and type and contruction and bristle of the brush, I would apprecitate that too.
From the Rockler (sale) website: "Redtree Industries� Badger Brush is handcrafted with 100% natural bristle, making it a top choice for oil-based paints, stains, varnishes, urethanes and shellac. Wooden handle with rounded contours provides excellent balance and deft touch, while the thick head of bristles holds a generous amount of finish for extra-smooth flow and even leveling. Chisel trim allows you to cut in sharply and cleanly. Made in USA. "
Re: super quality brushes
>A soft bristle nylon/polyester from Purdy, Wooster, or Sherwin Williams is all you'll ever need. A badger hair brush isn't necessary.
Clint
John_in_Az
>Unless it is a brush I just intend to use one time for a job that doesn't require a fine finish I won't use anything else but a Purdy. A Purdy is great quality and cleans up easily time after time. I have Purdys that have been used many times and still perform like new. You can buy a Purdy for say $10.00 and it will still be useful longer than 5 - $3.00 brushes. John
Kneale Brownson enjoying snow in N. MI
>I have a bunch of Purdy bristle and man-made fiber brushes I have used for years and years. I've always used a bristle for all oil-based and a nylon for any kind of water-based covering. I've purchased a couple of the exotic bristle products for varnish projects, but never found them to be any better than the Purdys, which are available at most good paint stores.
Steve Schoene
>There is a class of brushes above the Purdy's. Whether they have benefits for you depends on a lot of factors. One place to see a good selection of them is homestead finishing, Jeff Jewitt's on-lilne store.
The place where the most difference is apparent to me is for shellac where I like the Taklon gold bristles. This isn't a universal preference, others don't like the small reservoir of these brushes, but I find that overlaps and the like are of such little consequence that I don't worry about having to take extra brush strokes.
The merits of a great varnish brush are a bit problematic since properly thinned varnish flows out quite nicely with brushes of the Purdy caliber. I do like the ones with an ox hair blend for varnish, Purdy makes one and Corona also has a good brush with ox hair along with the bristle.
Howard Acheson
>I have two badger hair brushes I bought about 45 years ago when I worked a summer as a painter in a yacht yard. There is no question that badger brushes are the best for varnishing but, one needs to know how to varnish or the brush makes no difference. A good varnisher can lay on a glass finish on the transom of a yacht that needs no further "rubbing". For run of the mill varnishing a good natural hair brush is fine.
For paint however, I would never use my badger brushes. A standard Purdy natural bristle brush is just fine for oil based paints and shellac. A Purdy synthetic brisle brush is fine for waterborne finishes.
While I use a standard natural bristle brush for shellac, I much prefer padding on shellac. You get a much better finish with padding. Shellac does not really like being brushed on except for one or two coats. Antique refinishers will generally use a golden taklon fan brush for fine shellac work.
Lee Grindinger
Even pig's hair wears out
Lee Grindinger
>I built and finished a bit of furniture over the years. In that time I mucked up many flat surfaces with carving that would not lend itself well to spray finishing. I nearly always used brushed finishes, alkyd varnishes, on my work. Boar's bristle, (China Bristle) was my brush of choice but after a few uses the hair would not wick the varnish as well as a new brush so I'd simply pitch an old (ten uses or so) brush in favor of a clean and sweet new China Bristle brush. I found badger hair too soft.
I heard about people keeping brushes for months or years and never actually bought into it as being the ideal way to approach brushes. The fact is that even natural bristle hairs clog, don't wick well after a few uses, and the ferrules spread the hairs. The bottom line for me was to buy a new China Bristle brush for every major piece of furniture, trash the previous brush on the first several coats, use the new brush on the final coats, then sacrifice it on the first few coats of the next piece.
Also, natural bristles work fine for certain finishes but really, really poorly for others. Never use a natural bristle for enamel, latex or water based pigmented finishes. Use polyester for those. Conversely, never use polyester for alkyd or poly varnishes, those varnishes simply won't flow through the hairs. Choose the right bristle for the right finish and plan on replacing it periodically, nothing works forever and the structure of a hair that makes it wick a varnish beautifully clogs over time and performs progressively more poorly as time wears on.
No brush will last forever and no single brush will spread all finishes well.
Lee
Jim Dillon
>Charles,
I've used a lot of Purdy brushes on paint, but I have also found the Corona brand to be top notch and VERY easy to clean. I think their synthetic bristle is called Nylex; and I would buy another in a heartbeat. I found them at a local Benjamin-Moore dealer, but then another B-M dealer stocked only the Purdy brand, so go figure. I have also used some of Jeff Jewitt's quality brushes (badger hair, Taklon etc) and found them to be excellent as well - but I would never use them for paint. My less than 2 cents worth of opinion.
Jim
Re: super quality brushes *LINK*
rarebear
>I use Badger for Shellac and have used the same brush for about 5 years.. I have dozen of more Purdy Nylnox or something like that that is Purdys answer to Badger and are OK but not Badger..
For vashish I use Purdy White China or black china but not nylon..
There was a seller on eBay that sold Purdy Seconds that looked like firsts to me other that the stamp but I just checked and has nothing listed.. When he had suff you could buy a dozen for the cost of one but mostly bigger brushed with 1 1/2 being the smallest and 2" and up the rule..
Link is below if you want to try and look later this month but last few times I checked has been nothing :(
New Seconds
cheap brush with a modification
Robin Corell in Atascadero, CA
>Ocasionaly I need a good finish with a product that I know will wreck a good brush. for things like fiberglass resin or epoxy resin I don't want to sacrifice an expensive brush yet I don't want a rough surface that needs to be sanded and rubbed out. what I use for these situations is a cheap china bristle brush that I modify by running a generous bead of medium thin CA glue compleately around where the bristles join the ferrule. What this does is to severly limit the loose bristles that are typical when using these brushes.
I wouldn't recomend this solution over a good quality brush for your every day finishing needs but it is a great trick to use in a pinch.
Robin
Corona Source *LINK*
David Yoho
>Woodcraft Supply carries these brushes. Check the link below.
David
Corona Brushes
Re: cheap brush with a modification
>I don't think I will be using that tip on my Purdy burushes ;) But it sounds like a great idea; thanks for the tip.
Gene Gauss
>My favorite brush for clear finishes is a 2" white china bristle Corona brush with bias cut bristles. By using it only on oil based materials, and cleaning it thoroughly (four times through minimum and NEVER do the final soap and water wash thing), I've been able to use it for at least the last ten years on polyurethane, as well as oil based outside white paint on windows and wooden storms and screens. I tried a badger brush, at great expense, comparatively, but didn't notice any difference in the final product, and on the first couple of uses, it deposited lotsa bristles in the finish. I have a couple of Purdys (black natural bristle), but they don't seem to me to do as well as the Corona.
Thanks David!
Jim Dillon
>Actually, the bristles on the Corona brushes I've used are completely black and are made from nylon and not polyester, I think. I gotta get out more as I wasn't aware of other types of Corona brushes, but I will sure try them in the future based on my great experience with that brand. Thanks again.
Jim
DizD
>Purdy or ugly, whats a brush looks have to do with the way it spreads finish?
Re: Even pig's hair wears out
Howard Acheson
Even for oil based enamel? After all, oil based enamel paint is just varnish with pigments added. I suspect you are referring to waterborne finishes regarding the use of synthetic bristles.
You and I can disagree on the long term use of brushes. The badger varnish brushes I have still perform perfectly after 40+ years. Of course, after the few months when I worked as a yacht painter, they are not used every day but they are well cleaned after every use. I have never heard a finisher say that well cared for brushes deteriorate to the point of discarding on the schedule you relate.
incredible!
Charles Yawn
>The experience, expertise and willingness to share on this forum is incredible! Thanks people. Charles
Ken Garlock, Collin County Texas
>Hi Charles.
I bought a several brushes from Homestead Finishing, and they are without a doubt the best brushes I have ever owned. I have a couple Purdy and Wooster brushes, but they can't hold a candle to the brushes from Homestead Finishing.
Happy Sawdust,
Ken
Good Quality brushes
Charles Yawn
>Thanks, Ken. I viewed the website and saved it in my favorites. Charles
