Router bit problem and solution *LINK*
Robin Corell in Atascadero, CA
>This morning I found myself in need of a 3/8" 14* 1/4" shank dovetail bit. I was not overly surprised that my local tool store did not have one, though I was a bit surprised that Amana does not even make one. I checked online and found that woodworkers supply did list one but figured it would be a couple days to get it to me. I then looked online to see if Her-Saf makes what I need and sure enough they listed one so I called them up and they had one in stock. The funny thing is that they are only a couple of miles from me.
For those that are not familiar with Her-Saf they make carbide insert router bits. they also make a few fixed carbide bits as well. the really unique part of their tooling is that the bit and the arbor are sold seperately. This is also true for their dovetail bits. I bought a 1/4" arbor for my trim router and a 2 3/8" long 1/2" shank arbor for my router table. My router table can stay set up with the shank at the same depth and with out losing that set up I can remove the bit and install it on my trim router and without losing that set up I can move it back to my table or swap it out with another dovetail bit that is sharp. Her-Saf tooling is made in the USA using c4 carbide and it is on a par price wise with other high quality tooling.
So far I am happy with the results and the parts made with the bit mounted in the diferent routers with diferent shanks all slid together nicely.
Robin
Her-Saf
