A55 Smoothing Plane
Shelf hardware???
Shelf hardware???
Shelf hardware???
Mike Jones, Redding, CA
>I recently saw some knick-knack shelves that projected out fom the wall without any visible support...that is, no corbels, brackets, or hangers. I want to know how to do this, what hardware is used, and what do you call the application? Links? Thanks!
Re: Shelf hardware???
Bruce, a MN Galoot
>I use a keyhole slot cut with my router. No visible means of support.
Bruce
John McGaw
>Insufficient information. Describe the shelves. Thin? Thick? Projecting how far? Supporting how much weight? Wall stud(s) available? In a corner or on open wall?
It can be as easy as drilling into the wall studs, inserting steel rods into the holes and then slipping a shelf made with matching holes over the other ends of the rods. Presto chango! -- an invisibly supported shelf.
Or it can get almost infinitely complex if you let it.
Floating shelves *LINK*
David Barnett - SW Florida
>I prefer torsion boxes with veneer. They're light, strong and easy to mount if you project rods from the studs.
Here's another way to do it
Lee Gordon
The Borg has them
Lee Gordon
>Home Depot calls their version "floating shelves" and Lowes calls theirs "bracketless shelves" but they both carry them.
Agree
>Torsion boxes on cleats are pretty solid in and of themselves (I'll never forget the picture of Ian Kirby sitting on one), but if you expect to put any serious weight on them, you could try another method that has also worked for me: Make the shelf from two pieces of plywood glued together with mating 1/4" x 1/2" dados spaced the same distance as the studs of the wall you're hanging them on. Get some 1/2" cold-rolled steel rods and install them into the studs to a depth of 3" (3 1/2" including 1/2" drywall). Finish off the shelf any way you like -- veneer, edgebanding, solid edges, whatever -- and slide it onto the steel rods. Usually there will be enough slop in the installation that the rods will hold the shelf quite firmly by friction.
A tip: Whenever you are drilling mating holes (or in this case, matching holes to pre-formed holes in your shelf), use a straight stick for a drilling jig. Mark and drill the stick on the same exact centers as your shelf holes, and then screw the stick to the wall to drill those holes. This way you can level the guide perfectly, and it serves as a drill bushing to keep your holes perpendicular to the wall.
Cheers,
Great responses, but...
>I must make these shelves of 6/4 cherry planks and curve the leading edge lengthwise to match a furniture piece. To complicate my project, I've got to build the shelves and ship them to my "all-thumbs" son, so the installation must be pretty simple and without much tooling. I was hoping to find some store-bought hardware to facilitate hanging the shelves, but short of that, I am capable of most shop functions (bandsaw, router and table, etc.) but would prefer not to have to fly 1000 miles to make that installation for him.
Dave Bair, Eaton Rapids, MI
>Try Lee Valley part #00S05.20, it's called a blind shelf support.
BINGO!!!
>BINGO!!! Thanks so much! This will work PERFECTLY!!
