>I did it by trial and error. I took a roll of freezer paper and cut the roll with a table saw (or band saw?), to an estimated width,
say 4", unrolled a strip and then cut angle on one end (you may have to adjust this) and wrapped it on the drum. At takeup end you have to estimate the angle & length and trim to fit. I wound up taking 1/4" increments off the width until I got the match to the sanding belt length I had. From the paper pattern, make a templete, lay it on back of belt & slice it off.
