Wooden walk-off mat??
tom norton
>Has anyone made a wooden walk-off mat for use in the garage? I would like a better way of controlling "stuff" from coming into the house from the garage. Especially in the inter.
Re: Wooden walk-off mat??
>I made a door mat for my sister. Just a bunch of strips about 1 1/4" wide and some spacers of the same size in between. Drilled them all to accept pieces of All Thread. Her last name started with an "I" so I made the center row of spacers out of a contrasting wood and inserted a longer spacer top and bottom to make an I. It worked well. Thanks for reminding me, I could use one in my shop.
No, sorry its been a while......
>Think of it as a cutting board with every other slat missing. Three or four short slats or blocks serve as spacers. I drilled the holes with a drill press, but it would be easy to set them up with a pattern and drill them by hand. Drill them a little oversized. You could also put a little glue on each block, but it is probably not necessary.
