>What are my options shingling a patio cover. The decking will be 3/4"plywood or 3/4" tongue & groove. I want to use composition shingles, but I can't have the roofing nails poke through the exposed underside. Thanks for any idea's
>Short 1" nails. By the time you put the roofing felt and the shingles on - you shouldn't have nails poking through. You may want to consider using the ones with washers to prevent you from going too deep.
>I would be somewhat skeptical about using short nails. There is a phenomenon known as a "Nail Pop". If the point of the nail is buried in the wood the seasonal changes in moisture content cause the wood to expand and contract and in effect get a grip on the tip of the nail and push it back out.
This was the curse of the early drywall industry. Their solution was to use shorter nails that were ring shanked. The shorter nail worked better because it reduced the "stroke" of the wood's change in dimension. The ring shanks gave the nails a much better grip.
The roofing industry has solved the problem by insisting that he nails be driven all the way through. If the tip of the nail is not inside the wood, the wood has a difficult time gripping the nail to push it back out. In my home inspections I find nails that have popped or backed out and they are usually the ones driven into the rafters or trusses below the sheeting. (Thus, the tip is buried.)
My suggestion would be to find some short ring shanked nails and use the washers if they have small heads.
