Re: I wouldn't worry to much......
Brian in Brighton
>ABS should not be a problem. They work with a little sensor seeing a tooth on the moving wheel flying by it. The teeth are cast into the wheel like a gear. The idea is so simple you'll slap your head when you hear it. The control box keeps a watch on all 4 sensors, when one of them stops sensing the teeth and the others are moving the control box shuts off a valve that sends fluid to that wheel. There is a little back relief on the valve to that pressure in the line is relieved. It will hold the valve shut until it starts to sense the teeth again.
So the only issue with braking would not be the ABS but might be in the brakes themselves. They are designed to stop 2 wheels on a side, not one. So they will have a lot more braking force since the friction on the road is cut in half. I don't know about the master cylinder for a dually, but it might have a different pressure for the rear wheels than the front that will also be messed up.
My 2 cents is to take them off and try it. The worst that happens is that you keep locking up one set of wheels or the other. The tranny and axle should not care. Now if you were to take a single wheel and make it a dually, I would say you could mess up all kinds of things.
Brian in Brighton
