Re: Resawing Outta Wack
Grant in Iowa
>Howard,
When you get your new blade, I suggest you perform the following test:
-take a board at least 12" long and with one straight edge and draw a line parallel to and about an inch from that edge
-Set up your saw, and without using the fence begin cutting along the line by freehand cutting. Follow the line until you find the equilibrium point and can cut along the line with no side to side corrective movements and then STOP cutting where you are, hold the board at that angle and shut off the saw.
-Set up you saw fence parallel to this line, and you should be able to use the fence (with that blade and that saw alignment) to cut parallel to the fence.
-If you find that you can't reach an equilibrium point and are constantly correcting left to right in order to foillow a line, then your blade is dull or perhaps inappropriate for the material being cut.
Hope that helps,
Grant in Iowa
