I need help finding a hinge,
Keith Newton
>Like James Krenov would use. It needs to be a brass pivot hinge. The part which mounts on the top and bottom edge of the door is about 1/8" thick, L shape, 3/8" x 3" on the long arm.
The cabinet part is about 3/8" x 1.5" long. I have used these a lot through the years, but have loaned my catalogs out, or left them with customers to choose pulls, and didn't get them back. I have wasted more than an hour looking online, but I need a part #
If someone has a catalog, and could look under pivot hinge, or knife hinge will get you on the page. Thanks
Re: I need help finding a hinge,
Re: I need help finding a hinge, *LINK*
>Lee Valley sells them. I repaired an old wardrobe and the pivot hinges were made from the ramrod guide from a muzzleloading rifle.
Stephen
Pivot/Knife Hinge
That is not it. I need L
Keith Newton
>The door part needs to be L shaped because it is inset.
I can find them where both parts are L shaped, but I don't want to have to mortise the carcass part because the cabinet is already made, and I can't get a router into the corner.
Thanks for trying. The one that I want would be on the same page as this, but I can't find it without a part #.
Re: That is not it. I need L *LINK*
>How about this one.
Stephen
L-hinge
Try looking for clock case hardware
Rod Peterson -- Ormond Beach
>I've used those for the door in the hood of a tall case clock (grandfather/grandmother). KlocKit has them. I'm sure there must be other places, too.
Rod
Ed Mulligan, Cape Cod
>Keith
There are six possibilities at page 2 of the link. Ed
http://www.whitechapel-ltd.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=wc&Category_Code=sphng&Offset=
Whitechapel
Thanks, Order placed
Keith Newton
>Not what I wanted to find, but close enough. I can make the base part easier than continuing the hunt.
Dang those things are expensive for such a simple hinge. If I needed more than just two pair, I think I would jig up and make my own.
Re: Thanks, Order placed
Mac
>Whitechapel gives a substantial discount to businesses(business card?)
Sonny Asburry
>I read that you had already ordered the hinge, but for future use, here is a source that might be of use.
It is located here in Martinsville, Va.
I have no affiliation, nor have I dealt with them.
I hope this helps.
coolknobandpulls.com
Sonny
