200+ woodworking book reviews
Routing a large cavity
Andy in Raleigh
>I need to hollow a cavity in 8/4 hard maple. I am making a jouhikko (simple bowed instrument native to Scandinavia) for someone. Anyway I need to excavate about 1.75" deep in a rectangle about 6" x 15". One common method is drilling a network of holes and then chiseling out the remainder. It occures to me that routing with a slowly advanced straight bit might be another alternative. What I was thinking was drilling to make an L shape and using a router guide (I don't have a router table, but I have a rail system - the Tool Trolley) to clean up the L. Then I could could use my router guide to keep expanding the width of the long side of the L. The short side is there so I can start already plunged each time across. Is this a reasonable way to do it? How much could I advance the guide each time? If I could nibble off 1/4" each time, it would be a lot easier than drilling and hand carving it. Even if it is only 1/8", it's probably simpler.
Re: Routing a large cavity
North of the Border
>Have you considered creating first a template / pattern (say out of a 1/4" ply) and double tape or tack it onto your workpiece) and then using a pattern bit (something like this: http://tinyurl.com/32spq3 ) to hollow out the materials to the right depth?
Andy in Raleigh
>I don't understand how that would work in the middle of the cavity. I am also concerned that routing out the full depth (almost 2") for the full width of the bit is also problematic (yeah, I know, with a router powered by a small block Chevy and a bit made of unobtanium, it's no problem; I am a bit closer to consumer grade).
John McGaw
>It is more difficult to explain than to do, honestly. Think of a template with an opening 1/2" larger than your desired recess in each direction (10X12 recess gets a 11"X13" opening). Template is stuck down over the stock via DS tape or brads. Then imagine a rigid bridge which supports your router above the opening which is over twice as long as the opening but not much wider than the router base. Your router is in the middle of the bridge with its bit pointing down. Surrounding the bit is a collar which just fits down into the template enough that it cannot escape and which is 1/2" wider than the bit. One starts with a shallow cut, sliding the bridge/router back and forth until all available wood is gone. Router is set deeper and the process is repeated until the recess is deep enough. The key is that the bridge supports the router above the stock and the collar keeps the cutting within the template opening.
If you do some searching online you can probably find a description of making a tray with a router and the process and jigs are the same. This would be an ideal job for an overarm router but I don't know anyone who actually has one of the beasts.
John Foster
>My neighbour has a big engine driven sandblaster (don't laugh) you would be amazed at how much control he has carving wood. Don't know what type of hollowing out you want, but this is a way you could dish it out.
This is going to sound wierd
woodenleg
>Call a shop that makes wooden leg or artifical arms. The shop that I go to has a router(thats what they call it) that they can swap bits from a big burr to sandpaper flap wheel. The shaft is about 2' long. They have to get into deep sockets. My shop does this for money or pr or???. Most of the people who work in these shops are good with wood and their hands. Good Luck. Dave
Peter Stahl
>Take your base plate off and make one that is about 16 - 18 inches long so it will span the hole you want to make. Good quality birch ply should work good for this. Use the router plate as a template to make the holes for the new base plate. If you think you'll do this a lot then get a nice piece of phenolic plastic of aluminum for the base plate.
Steven Antonucci
Use a forstner bit first
steve antonucci
>then use the router to finish it. I'd even break out the leftovers from the drilling with a pair of pliers before going the router way.
You'll need to make a faceplate for the router wide enough to ride the rails too. Use a 1/2" sheet of plywood that's 3x the width of the box, and just work back and forth slowly.
Steven
You're right ;->
Andy in Raleigh
>I will potentially need to do this somewhat often, so I want to figure out the best way to do it myself. But I will keep that in mind for future projects.
Thanks!
Andy
Robby Wright
>How about doing it like a bandsaw box? Resaw a slab of the desired thickness from the bottom, then saw out the middle and glue the remaining rim back onto the bottom. Viola! Use hide glue and you will have a solid connection between the top and bottom. Hide glue is commonly used in instruments.
Another way would be to make a template out of 1/2" ply with an opening the size you want. Put a pattern bit with the bearing on the shaft of the bit in your router table, set so the bearing is just above the table. Predrill a hole with plenty of clearance in your blank, lower the blank over the bit so it isn't touching the blank, fire up the router and route away.
Robby W.
