PM2000/Accufence issue
DizD
>Riping some fairly short strips this weekend and noticed a gap between straight edge of the strip and the fence when the strip projected beyond end of UHMW fence side. The gap disappeared when wood cleared end of fence. Checked with a long straightedge and found the two ends of the fence face have kicked out ( away from fence beam).015". The movement in the fence face is from the last attachment bolt to the end. I'm reasonably certain the face was flat when I started out with this saw just over a year ago. I will work on shimming to see if I can bring it back in line. Just wondered if anyone else has noticed this? It appears the unattached ends of the UHMW sides are reacting to stress at attachment points. Will shimming correct this?
