Did this…
Rod Peterson -- Ormond Beach
>First of all, get acquainted with the nice folks at the John Bridge Forum. It's the WoodCentral of tilesetting, and it's loaded with professionals and experienced amateurs who not only can give you a great answer, but can help shepherd you through all the potential pitfalls and anxiety points of the job.
My project turned out not to be as hard as I made it out during the various steps (which you can see at my house remodel page on my website, under Master Bath). I made several visits to John Bridge during my project for propping up and other advice.
The specific answer to your question is that I believe the weep holes are hard to find or are less weep “holes” than very thin slits in or near the threads, but they're there.
One piece of advice I wish I'd taken the time to follow—either shim or notch the studs in the shower area to accommodate the folds of the liner where they go up the walls. Even though the liner is sort of thin (compared to the thicknesses of the tile and studs), two additional layers of it does visibly affect plane of the tiles, and you won't really realize how much until the tile is in and the shower ready for use.
And one thing I did do, and I'm glad, is to let in 2x8s around the inside of the shower area so that if you eventually put grab bars in, you won't have to worry about finding the studs—you'll have plenty of anchor stock to hit. Don't forget to take some pictures and/or otherwise document how high and what width so you can find them later.
Although they sell “moisture resistant” sheetrock at the box, use cement board (Wonder Board, HardiBacker, DuRock, etc.) as your tile backer throughout the shower stall. You will never worry about disintegration or mold later.
Give some thought to putting in a simple seat, if you have room. I didn't (although I had the room), and although I can't say I regret not doing it, every once in a while I ask myself if I shouldn't have. Just something to think about.
Finally, don't worry about the corners of the liner at the ends of the curb. Some manufacturers make a prefab corner you can glue in to avoid leaks at that point (should the pan overflow), but after thinking about it for a while, I realized that the curb represents the high water mark in any event, and preserving the integrity of the liner at that point was minor compared to the exigency resulting from the water being that high in the first place.
Have fun.
Rod
