Turning the heat up
Lee Grindinger
>First of all- No, you don't need a kiln to dry lumber, you can do a perfectly adequate job without anything more than a few stickers and some attention.
I'll try to clear up a few things. The whole science of drying lumber is based upon how quickly moisture at the surface can be replaced with interior moisture as it's removed. As you get further from this moisture migration rate the more likely drying defects occur. Different species have very different migration speeds. Back when I ran two kilns I joked that I could build a fire under pine and poplar to dry them. It was, of course, an exaggeration but it points out how different one species is from another. Some woods like hickory, birch and oak dry much more slowly.
Heat speeds the movement of water through wood. Conventional hardwood kilns are generally run around 185 degrees Fahrenheit to speed the movement of water through the wood tissue. Water in wood takes two forms, free water which is the water between cells, and bound water within the cells. Free water is easy because it does not have to penetrate cell walls to get out and it can be removed at a very fast rate because no wood shrinkage begins until this free water is gone. In fact, free water will literally form a puddle on the floor under a freshly cut board stood on it's end.
It's when this free water is gone, called the fiber saturation point and is around 28% moisture content, that drying becomes more challenging. At this point it becomes important to remove moisture from the surface at about the same rate as the water migrates through the wood tissue. For ambient temperatures such as yours the slower the better. The big boys with their big boy kilns can do what's called conditioning to compensate for issues caused by fast water removal, you cannot and virtually every defect caused by a kiln can be caused by air drying. Like I said, slower is better.
Use dry stickers. Watch for mold. Mold will look blackish or blueish and is not a serious issue unless it persists. Mold cannot flourish above 18% and this is the next critical moisture barrier in drying lumber. If you notice mold on the lumber (think bread mold) change your stickers weekly to avoid sticker stain and increase the air flow slightly but not so much as to cause to much moisture removal and the resulting defects. A bit of mold comes right off in the surfacer so it can be ignored but sticker stain, a problem with cherry, cannot.
Restrain your pile! A couple hundred feet of wood is not much so you'll need to use weight or clamps to restrain the boards as you dry them. I never met the board that would remain perfectly flat by itself during drying but most will succumb to gentle and not so gentle persuasion and remain quite flat after drying Use any means you have to to keep the boards flat during drying or you'll likely end up with potato chips.
Plan on 6 months at least. Take your time and bring your wood into heated areas next fall, this will complete their drying. At this point you can stand them on end or store them in any way that keeps air movement around them.
Okay, enough drivel, I probably raised as many questions as I answered but ask away. I'd urge you to try this, it can be very special to build something out of wood you dried yourself but make sure it's decent wood. If it looks crummy as it's sawn it will look twice as crummy when it's time to look for clear cuts in the workshop.
Lee
