Refinishing hardwood floor Q's
KurtK in Indy
>I think I'm going to tackle sanding and finishing my hardwood floors. The question I have is does anyone have an idea of the going rate per S/F for having it done professionally?? I'm thinking if I can do it right and with any ability, I may see about doing it for others if the money is any good. I need some extra $$ and my weekends are pretty available. So I'm going to do my own floors as a barometer and then decide if the pay is worth the pain.
Thanks for any insight
Kurt
Re: Refinishing hardwood floor Q's
Be sure and get a good sander.
henthorn
>Don't use those dumb drum sanders some outfits rent out.
dtenney
>I've done quite a few floors. Bot new installs and refinishes.
If the floor is in bad shape, you will have to use a drum sander...No way around it.
Here's a pretty good article on this:
http://www.hammerzone.com/archives/flooring/hardwood/sanding/drum.htm
If the floor is in decent shape and just needs the finish knocked off, you can use a random orbital saner. This type of unit has 4 6" pads on the bottom of the machine. When I use this I only use two grits...The roughest (usually 24) and 80 grit to finish. I use this on new floor installs also.
When you finish the floor, put down a coat of shellac based sanding sealer. This will make the job go a lot faster. After the shellac dries, put down your first coat of poly. After that dries, sand the whole floor with 80 grit in a pad sander. Then whip the floor down with warm water and towel off. You can now apply the final coat of poly.
I've used different brands of polyurethane, and haven't noticed any difference between them. I mainly use Parks now because it is the cheapest and looks\works the same as the more expensive brands. You can buy it at HD.
Hope that helps.
dave
Jason Roehl in Lafayette, IN
>Hey, Kurt, I don't know about down in Indy, but in this neck of the woods, typical rates are about $2.50-$3.00/s.f. The lower end is for putting on just a clear finish, add about $0.25 if it's to be stained.
Don's right--drum sanders stink. Belt sanders are the way to go, and they'll give you a bit of a workout, but it's the edger that will have you curled up on the floor crying for mommy at the end of the day (okay, maybe I'm exaggerating a bit here...).
I think you'll find that refinishing floors is more than a weekend job, especially when doing it for others. When you're by yourself, 1000 s.f. of refinishing can take 3 days to do well, and that's using waterborne finishes. Not to mention, it takes a pretty hefty equipment investment to do that--using junk rental equipment will just slow you down. Do a Google search for NWFA or NOFMA (I forget what they stand for, but they're the two main wood flooring associations in the U.S.).
Jason
Tom Goltl
>I've done several floors, and I'll use two diffenent machines. I'll use a drum sander to just take the original finish off. Either using 60 or 80 grit paper. When that's done, I use a machine called the U-sand. It is 4 6" random orbital sanders. Home Depot rents them in my area. You can't mess up the floor with this machine. I buy the sandpaper from Klingspor. It goes to the edge, so no need for an edge sander, inside corners need a little work. Go to www.usand.com and take a look. I've then always used the Varathane water based floor finish. Always looks great.
Tom
Good work costs.........
Andy Halterman: Purple iris up
>good money.
$2.50-$4.50 for us depending on what it is we're sanding and the finishes they spec. Satan's spawn the architect and interior designer can come up with some really great brainstorms. (insert rolling eyes here)
Yes, a cheap shot at the architects and decorators but you guys/gals do make my life difficult sometimes. Just keep the work coming and I'll suffer through it with a smile.
Andy Halterman
I'm not cheap nor am I easy in Hendersonville, NC�
Justin Szeliga
>The usual problem w/a drum sander is the loose screw on the handle. Those machines are VERY POWERFUL, VERY HEAVY, & take some time to get used to using. I gave up trying to be a guy who also does floors about 15 years ago when I did my sisters & got shocked by the machine (bad ground) & had to wait 2 days between coats (August, New Jersey, 1,000,000% humidity, Minwax poly) & I can still see spots I laid a bit too much finish on. The machines are difficult to keep control of, but with care & patience a competent person can do an OK job. It's just going to be hard work w/a very high chance of making a huge mistake.
Very hard work, & you shouldn't walk on the floors between sanding & finishing. Very difficult logistics. I am never gonna sand another floor, ever.
Peace
Justin
