finishing
finishing
finishing
B Wood
>I am building cabinets for our master closet. I am using furniture grade cherry plywood for the case and solid cherry for the face frame. I want the cabinets to look as "furniture-like" as possible, but it is a large project (17 sheets of plywood and 20 bd ft of cherry). I was thinking of applying Watco Danish Oil for depth, then polyurethane for durability. Any thoughts as to whether this will achieve these goals or does anyone have any suggestions as to what to do? Thanks. BWood
Re: finishing
Re: finishing
rarebear
>For me I like cherry with a oil finish..
I think this will look awesome with a low luster finish and more old timey they high luster in a closet.. You can wipe the wood with BLO every year and the finish will improve every year IMHO
Re: finishing
Re: finishing
>Several years ago, I made a pair of low dressers using rotary cut cherry ply. The appearance is totally different from solid plain or quarter sawn cherry. In my opinion, it starts out dull and lifeless and gets moreso when finished. It may just as well have been birch or aspen with a stain. Excuse what may seem presumptious, but unless you have already acquired the cherry, compare it with ash before making a decision. Good luck with the project.
Clint
Re: finishing
Re: finishing
Dick Coers
>I would caution you about using that type of finish for inside the closet. You may get outgassing as the finish cures for a long time and will hold a smell in the closet. I suppose if you let the cabinets cure for a month or so before installation it may be okay, but maybe not. I would consider shellac for the color and then a water base poly for the hard finish.
Re: finishing
and that is the downside
Bill Tindall, E.TN
>If you are not into redoing the oil periodically then coat with varnish of your choice. Personally I would start with a stain than then varnish. For a job this sized you may want to learn to spray.
Re: finishing
Re: finishing
B Wood
>Thanks. I didn't think about the smell. I have never used the water based poly before. Are the results the same? Also, what do you think about putting the Watco oil on before the poly? Good idea or bad?
Bill
