Wipe on poly..Make it?
Virgil Johnson, Versailles KY
>I know the folks who make finishes have enough problems and they know what they are doing...I'm not trying to re-invent the wheel just use up some Minwax fast drying poly before it hardens. I have a small table that needs finishing and I'm thinking about diluting the poly around 30% with mineral spirits and wiping it on. Good or bad idea? I would buy a can of Deftoil but I only need about 4oz and at the rate I'm using finish these days this too would harden before I use all of it. Thanks.
Re: Wipe on poly..Make it?
Steve Schoene
>Sure, no reason not too. The % of thinning isn't at all critical, lots of people recommend 1:1 ratios, but if you are comfortable with 30% thinning for wiping that will build a bit faster and work just fine.
Howard Acheson
>Here is something that should help. A friend of mine put it together years ago and it has worked well for many.
QUOTE
There are a number of suggested application regimens that are totally subjective. The number of coats in a given day, the % of cut on various coats, which coat to sand after, when to use the blade and a whole host of other practices are all minor differences between finishers. There are some things that I consider sacred when applying a wipe-on finish.
First, you can use any full strength oil based clear finish. Polyurethane varnish or non-poly varnish is fine.
If you are making your own wipe-on the mix is scientific - thin. I suggest 50/50 with mineral spirits because it is easier to type than any other ratio and easy to remember. Some finish formulators have jumped on the bandwagon and you can now get "wipe on" finish pre-mixed. If you use a pre-mixed, thinning is generally not necessary. But making your own is cheaper and you know what's in it.
The number of coats in a given day is not important. Important is to apply a wet coat with an applicator and merely get it on. Think of a 16 year old kid working as a busboy at Denny's you have sent over to wipe off a table. Sort of swirl the the material on like you would if you were applying a paste wax. Don't attempt straight strokes. The applicator should be wet but not soaked. The applicator can be a paper towel, half a T-shirt sleeve or that one sock left after a load of washing. Then leave it alone. The surface should not be glossy or wet looking. If you have missed a spot, ignore it - you will get it on the next coat. If you try and fix a missed spot you will leave a mark in the finish.
Timing for a second coat involves the pinkie test. Touch the surface with your pinkie. If nothing comes off you are ready for another coat. If was tacky 5 minutes ago but not now, apply your next coat just as you applied the previous coat. Remember, you are wet wiping not flooding. After applying the second coat, let it fully dry for 48 hours. Using 320 paper and a sanding block lightly sand the surface flat. Now, begin applying more coats. Do not sand between coats unless you have allowed more than 24 hours to elapse since the prior coat. The number of coats is not critical - there is no critical or right number to apply. For those who need a rule, four more coats on non-critical surfaces or six more coats on surfaces that will get abraded seems to work.
After your last coat has dried at least over night you will have boogers in the surface. You should not have marks in the surface because you ignored application flaws. You may have dust, lint and, if you live in Texas, bug legs. Use a utility knife blade at this point. Hold it between your thumb and forefinger, near the vertical, and gently scrape the surface. Gentle is the important word - no harder than you would scrape your face. If you start scraping aggressively you will leave small cut marks in the surface. After you have scraped to the baby butt stage gently abrade the surface with 320 dry paper or a gray Scotchbrite. Clean off the surface. Now, leave the area for two hours and change your clothes. Apply your last coat with a bit more care than the previous coats and walk away.
An anal person is going to have a tough time with this process. Missed spots have to be ignored. Wet wipe, don't flood. Scraping to babies butt smooth means scraping no harder than scraping a babies butt. Ignoring any of these will leave marks that are tough to get out. Getting these marks out requires some aggressive sanding to flatten out the surface and starting over.
Jim Kull
END QUOTE
Finally, It works better to use a gloss varnish for all coats except the last. The flatteners in semi-gloss and satin tend to rapidly fall out of suspension when the finish is highly thinned. If you want a non-gloss finish, use it only on the final coat or two and be sure to stir the material frequently or you will end up with cloudy streaks.
Plan B
>I found some orange shellac flakes that I bought late last century and have those melting in alcohol. I gave the table a coat of BLO yesterday. If the shellac is still good then I'll use it as a topcoat. If not more BLO and wax.
Jim Dillon
>Virgil,
I've done it and it works just fine, but I wouldn't dilute a satin polyurethane more than 1:1. I had a good laugh when I read the last paragraph in Howards post. I used a 1:9 dilution of a satin PU on a hardwood floor once. Hey, if a little dilution is good, a lot will be even better, right? Came back the next day and the entire floor looked like it was covered in chalk dust. Turns out, the silica in the PU had precipitated out. Taking a deep breath, I recoated the floor with normal 1:1 dilution and everything turned out fine. Go for it.
Jim
