End tables
End tables
End tables
mfoster
>I am mostly a turner, but occasionally I venture into the dark/flat side to complete something for our house. I've spent the last couple of months building some end tables to complement our new couch and a pair of really nice lamps made by a local pottery artisan. I took inspiration for these from a number of sources, but heavily on the Shaker tradition because my wife and I both like the spare clean lines in Shaker work. I also took inspiration from Garret Hack, and much of the joinery was modeled after a few of his pieces shown in FWW. I went all out (for me) doing a lot of hand work with planing, scraping... The joints are haunched and pinned mortise and tenons, bridle joints for the drawer runners, breadboard joints mortised into the legs for the shelves and dovetails for the drawers. It was fun to do, but I could never make any money at it. Cherry, curly maple, kingwood (pins and knobs) and butternut for drawer bottoms. Thanks for looking.
Re: End tables
As one who is always . . .
Robert R Clough - Thorncraft
>interested in design, what design reasoning led you to breadboard the shelf, This is NOT a criticism. Standard design has the top breadboarded and the shelf plain - but standard doesn't mean "must" or "always". The next question, based on the same reasoning if you will, is why two drawers and of unequal size?
Mind you, I like the table and consider it one I could see here at home.
Robert
Re: End tables
Elegantly simple; simply elegant
Re: End tables
Re: As one who is always . . .
mfoster
>Thanks Robert. I decided to join the shelf with breadboard ends mortised into the legs to minimize possible racking seasonal movement of the shelf will have on the mortise and tenon joints in the leg and apron assembly. I live in Vermont, and seasonal humidity swings widely as evidenced in a number of doors (frame and panel) that were painted, but now show unpainted surfaces because they were painted in the summer. The shelf is a prime piece of 18" curly that I have had stashed for a while waiting for a place to showcase it. If the board were simply mortised (or otherwise attached) to the legs, I would expect seasonal movement of up to 1/4", which I figured was just too much stress on the rest of the piece. Breadboard ends solve the problem.
The drawer assymetry was an idea I found on another piece while looking for design inspiration. I think it was another piece by Garret Hack (a larger table, maybe a hall table or something like it). I liked the bit of tension it creates, and with a pair of tables around a couch, they then become symmetrical (they are mirror images of each other). I was pushing the limits of my photo booth taking a shot of a single table, but may post another pic with them in place around the couch later (they're still in the shop).
Mike
Re: End tables
Re: End tables
Warren E. White
>WOW! I really like the table. Your execution is elegant. I would like to build one just like it.
Thanks for sharing your project with us!
Warren
Re: End tables
Very niecly done
Craig in SIlverdale
>I love the small remote control drawers on the the tables. Now if I could only conquer the dark side of the spinnie thing. So far I can only make missiles in the workshop. I really like your work. Thanks for sharing.
Re: End tables
>Well, as a former Marbleheader and current SE Wisconsinite, I fully understand wood movement and humidity. I rather like the breadboarded shelf, It is different. And yes, I can see what youo mean re: the drawers. Your table is certainly Shakerlike.
Please, do not stop making furniture. You appear to have a knack for it. Perhaps you should look at "The Shaker Legacy" by Becksvoort and "Pleasant Hill Shaker Furniture" by Pierce. I especially like Pierce. His book is very closely written and must be read carefully but the wealth of knowledge shown makes the work well worth reading. Becksvoort's book is an excellent compendium of furniture, interior shots, and discussion of Pleasant Hill primarily.
Re: End tables
Nice curl!
Lee Schierer - McKean, PA
>I love the wood. Is it optical illusion that the front edge looks wavy? What was the finish you used??
Lee
Re: End tables
who cares
Tom Sontag - St. Louis
>if you can't make money at this kind of work? You've come up with an inspired design which balances amazing figured wood with another wood in a way most of us can only wish for. I think the breadboard shelf is a huge part of this success. Congratulations on a huge success.
Re: End tables
Re: Nice curl!
mfoster
>Lee, it is just an illusion from the curl of the wood. For the maple, I used an analine dye to pop the curl first. Sanded this back some, just enough to remove it from the light areas and leave dye in the darker parts of the curl, and to remove the fuzz caused by the water based analine. I then used Waterlox oil to really pop the curl. The cherry received a base coat of shellac to prevent splotching. Once these had fully cured, I used Minwax wipe on poly as a top coat on both. 5 or 6 coats on the top, 2-3 everywhere else. Light buffing with 0000 steel wool and Butchers wax to top it off.
Re: End tables
Re: End tables
mfoster
>Thanks all for the nice comments. It's encouraging to have fellow woodworkers give positive reinforcement.
Re: End tables
You earned 'em........
Andy Halterman: Purple iris up
>with the fine work you did.
I love the asymmetry of the drawers. Just a very nice step away from the norm.
Nice job.
Andy Halterman
Freeze/thaw evident on the trails today in Hendersonville, NC�
Re: End tables
Shop Shot, Please
Martin from Granbury
>You've made the grade to be a shop shot.
Nice design, excellent workmanship, beautiful wood and finish.
Thanks for posting.
Re: End tables
Garret Hack would be proud ...!!
Jim Dillon
>... and so would the Shakers. It is a lovely piece and what a gorgeous finish. Thanks for posting such an inspirational work.
Jim
Re: End tables
Very nicely done. Congrats!
HC Sakman
Re: End tables
Re: End tables
rarebear
>Very Nice,
Love the Maple......
