motor speed controler
Wayne
>Is there a controller that I can put in line with a 8" bench grinder to control the speed?
Re: motor speed controler
The simple answer is no
Forrest Addy
>The simple answer is no.
The speed of an nduction motor is determined by line frequency. You can slow it down by reducing the line voltage until the motor falls out of sync but as soon as you apply a load to it the grinder will slow down if not stop.
Whats your intent?
Grinding lathe tools
Wayne
>No matter how lightly I touch the wheel it wants to burn the edge the wheel is 80 SC. I might have to go to a green or white wheel. Thought about adding a drip to the wheel don't know ow that would work.
That's what I was thinking
Forrest Addy
>It's easy to forget that a grinding wheel has cutting edges. They are the sharp corners on the abrasive grains in the wheels periphery. These grains don't last forever. After some period of use the abrasive grains get dull, rub against the work instead of cutting it, and overheat it before significant grinding is accomplished. The grains can't be sharpened but since there are millions of them all the way to the wheel's hub, they can be dressed away to expose fresh sharp grains and in doing so true up the wheel and straighten out wear and grooves in the process.
Do not use a "green" wheel. They are silicon carbide and unsuited for grinding steel especially unsuited for fine grinding of cutting edges. I know some people swear by them but professional sharpening shops use them only for grinding back the shank to get clearance for diamond grinding brazed on carbide tools.
Use only aluminum oxide but don't get lost in pursuing ideals when the basics of wheel care and dressing have yet to be implemented.
Grinding wheels work best when run about 5500 peripheral feet per minute. Slower or faster and the efficiency of the process suffers.
There are some marketers preying on naive woodworkers selling them "slow speed grinders" that is bench grinders running at about half the effective working speed if the wheel. They want you to buy a whole new grinder to solve a problem with the wheel dress. Problem is there's an initial performans advantage. The wheels mounted on the slow speed grinder are new and shap. They work very effectively causing the naive purchaser some gratification - until the wheel wears and the purchaser is back in the same boat: burning sensitive cutting edges attempting to grind with a dull wheel.
The solution is to "dress" the grinding wheel to expose fresh sharp abrasive grains and true the wheel's periphery. This is simply done with a star dresser (which trues and opens the wheel's structure but leaves the surface rough for fine grinding) or a diamond dresser (which is preferred for dressing whees for fine grinding).
The star dresser is a heavy cast handle with hardened star shaped wheels on an axel. It's used by forcing it into the running wheel while rapidly traversing it across the wheel's face. It generates clouds of abrasive dust so have adjacent surfaces and machinery covered, a shop vac nozz;e in capture position, or best a hose from a dust collector.
A diamond dresser comes in many forms but the best for a bench grinder is a heavy hand shank that accepts a diamond cluster in the end and held with a set screw. It's used similar to the star dresser but with less force and vigor. It also generates clouds of dust etc. Keep it cool by dipping it in the water bucket.
Dressers are available from import and machine shop supply houses. Here's a start:
http://www.amazon.com/Commando-Grinding-Dresser-Diamond-Surface/dp/B0002BW6Q8
