I'm interested in routing the edge of 1" thick plywood for a window seat. I plan on using a roundover bit for this. My concern is that at some point the bit will jump or hit a gap between layers or some sort of irregularity and i'll chip off a piece of my edge. I plan on using the best quality plywood i can find at lowes or home depot (as much as i hate shopping at the big box stores) - i think they sell birch plywood?
Anyone have any tips or suggestions on what type of plywood i should use? I'll be using a handheld router.
>If I were in your shoes, I'd apply a solid wood edging to the plywood. You won't have to worry about voids.
If you don't want to use solid edging, then I'd recommended Baltic birch plywood. It tends to have few voids and machines nicely. The routed exposed edge doesn't look bad at all.
>I plan on using the best quality plywood i can find at lowes or home depot....
I know what you're saying but I also know from experience that quality plywood together with lowes or home depot just don't add up. This brings up questions that might help us help you better.
First, you referred to needing 1-inch plywood. Do you mean 1-inch or 3/4-inch? You can find a "representation" of birch and oak veneered plywoods at the big boxes in 3/4" thickness but forget about 1-inch.
Second, do you plan to paint this in the end or stain it?
Third, if you're painting it, why not just attach a strip of solid stock to the plywood edge and rout your edge on that?
If this window seat is to be stained or clear-coated, are you going to like seeing the plies that routing the edge will expose to a greater degree? And, if there are voids (which is like saying - if the Pope was Catholic) in your routed profile, how do you plan to repair them?
One thing to look at doing, unless there's a specific profile you want for the edge, is pick out a molding that's thick enough so you can simply attach it to the plywood edge and be done with it. I don't think you'll come away happy in the end no matter what quality of plywood you buy because the routed plywood edge will not be strong enough not to break in some fashion.
