>All, I have a friend that is being released from the hospital and is wheel chair bound. He was told that code calls for a ramp 32' long rising 1" per every certain amount of feet. The cost of materials is beyond his and his wifes financial means. She was quoted 2 to $3k in materials. She was told that she could rent one for $740/monthas an alternative. Does anyone know of a cheaper alternative for these folks? It's sad that they can't get help from the government. If anyone has any better ideas, please let me know.
>Sounds like you're talking about a ramp from outside up to the front door. The ADA specifies a 1:12 slope, so there must be 32" difference between grade and threshold. But $2-3K seems high for that. That's about the square foot equivalent of a 8 x 12' deck. Seems like you could have an awful lot of that size deck for that money.
Having said that, the last deck I built was in the '80s. I'll bet lumber has gone up since then. Probably need 32' of rail, too.
Well, that was a lot of help. I think I'll just move along. My work seems to be done here.
>I agree $2-3K sounds high. The usual slope is 1 inch height per foot in length, so the length (and expense) of the ramp varies with how high the door is from the ground. Might want to check if there is another door to the house that would be lower, and therefore cheaper. Don't know where you live, but the men's group at my former church built several ramps for folks, and there is still a pretty active group of retirees that does this as a service project. The homeowner usually has to foot most of the bill for materials though. Might be something to look into. Another thought - boy scout troops frequently do community service projects, and a wheelchair ramp wouldn't likely be beyond their scope with a little supervision and fairly simple tools.
>I have a friend with a wheelchair and he will tell you that although the codes require a certain slope, he can use a steeper ramp safely. I suspect the code is based on someone with average strength maneuvering the ramp with no assistance. With assistance, say from an electric chair or from a person, the ramp may possibly be steeper.
However, if the ramp is outdoors where it can be seen and considered a permanent structure, you local building codes may apply - give them a call.
Local codes may vary, but the ADA requires a 1:12 slope or shallower. (link below) The length depends on the rise, of course. What makes some ramps far more expensive is the need for a landing to turn the ramp to fit into the available space. This landing is built like a deck and must be 5' square so the chair can make the turn.
From the same link below I found this information on ramp slope (there's a table for the numerically challenged):
1:12 (5 degree incline) - ADA recommended slope for commercial and public access ramps. Works for most manual chair users unassisted.
1:8 (7 degree incline) - Most unassisted manual chair users can use on short ramps.
2:12 (9.5 degree incline) - OK for most portable ramps. An able assistant required for those unable to power themselves. OK for strong, unassisted manual chair users.
3:13 (14.5 degree incline) - Stability a concern. Clearance under scooter at top of ramp needs to be considered. Works for lightweight chair/user with strong assistant. Works for loading unoccupied power chairs and scooters. Only the strongest unassisted manual chair users can use on short ramps.
We put one that certainly doesn't meet the code going into my house so my friend can get inside. It's way steeper than code allows but works fine for him. This ramp was made many years ago from pressure treated lumber. I just measured it - it's about 9' long with a 24" rise, made from two 2x6 stringers with 40" 2x6 decking with some 2x4 blocking under for rigidity. I covered it with non-slip pads for traction.
Someone with a saw, tape and hammer could make one of these in a few hours. If totally without resources, ask around at local churches and civic group. I'll be you'll get a crew and all the materials out there and get it done.
Also, my friend used portable ramps for years to get him into vehicles and houses. You might put an ad in the paper or ask around - someone may have some portable ramps they could loan.
>About 10 years ago I helped install wheel chair ramps. The group that provided the material was called CASA and our local church would get volunteers to build and install the ramps.
>Beside local church groups, you might contact your local chapter of Habitat for Humanity who may be able to put you in touch with a volunteer(s) willing to contribute their time and labor. I work with a group that has done ramps for both our church and Habitat. Good luck.
>I built a ramp for a friend last spring, materials for a 30' long x 4 ' wide L shape ramp with a 4' by 5' platform were about $1,200.
I tried to get info from electric wheelchair manufactures about how steep the ramp could be. All of them indicated that their chairs would work fine on an ADA compliant ramp.
ADA allows a 1:12 ramp so long as there is a platform every 20' along the ramp. In more than 20 years as a highway engineer, I designed & built many ramps steeper than 1:12 before ADA was adopted. We often had to remove these ramps and flatten them. I have never had a complaint on a 1:12 ramp. Another consideration is the length of the ramp.
>was offered by Mike Holmes. He had to replace one awhile back and explained the codes and designs ( for his area at least ). I remember it wasn't only the slope and deck involved but rails and footings that they were death on. Don't know if his shows are archived anywhere in these DEvil Machines but it would give you a good idea of the scale involved. And he does tend to over-kill.
>Having to use a wheelchair from time to time I understand a little about ramps. If the ramp is steeper then 1:12, it is hard to control the chair by one person in both up and down goings ( yes there are people who can do it). Wooden ramps are hard to control because of miosture, unless you paint or apply some type of roughness to the ramp. You need to have sometype of railing near the bottom so the chair or the persons foot doesn't get caught. You then need to have sometype of railing for the use to use if needed. There has to be a flat spot for the chair at top of the ramp, it is very hard to open the door and keep the chair from rolling back at the same time. One ramp that I have used had lag bolts threaded into the rail being used by the chair person so they could help pull or slow themselves down, this ramp was in an area where they get 5 to 20' of snow every year. Use some common sense when building the ramp, age, stength of user etc. and has said before check your codes. Dave
