table saw
table saw
table saw
Darrell
>Does anybody use the Grizzly 2HP,10" Hybrid Cabinet Saw, model#G0478. Is this a good buy. It's this one or the Craftsman Hybrid. I will use the saw just about every day. Thanks.
Re: table saw
Re: table saw
steve mackay
>I'm finally up-gradeing from Carftsman and just got in the Grizzly combo sander. Don't know about the table saw but this thing is a BEAST ! Except for knobs theres no plastic, all cast iron & steel. So far well worth the bump in spending ! And, BOY, are they fast !
Re: table saw
Re: table saw
>Good Morning Darrell,
Popular Woodworking has a couple very good articles/videos on their website. The Grizzly and Crafdtsman hybrids are both addressed, along with others. See that.
George
Re: table saw
Re: table saw
>A couple of thoughts - particularly if you will be using it every day.
Weight matters - the more "massive" and weighty the saw, the less likely it is to move and shift on you. The more massive the fence, the less likely it will be shifting on you.
The more power, the greater the ease of cutting thicker material.
That being said, if what you are cutting is 1" thick, you don't necessarily need a more powerful, heavier saw (a cabinet saw). A hybrid may do it for you. I've used a friend's G1023SL (Grizzly Cabinet saw) and it is a good saw. It runs $200 more than the hybrid Grizzly.
I wire the saw for 220 V if you go for the hybrid saw. My $0.02.
Re: table saw
Re: table saw
knotscott
>There are pros and cons to each Darrell, but either of those are good hybrids. The CMan has the commercial Biese fence, 44" wide CI surface, accepts Delta throat inserts, and has cabinet mounted trunnions. It's also readily available near most good sized towns, and has frequent sale prices. The Griz has a one-piece cast arbor carriage with trunnions mounted to the table top, and a beefier motor (check the amp draw vs your circuit).
The 22124 has been a solid performer for me for nearly 3 years. Have you checked out the Steel City 35601 (very similar to the 22124) and the Jet Proshop 708482K?
Re: table saw
Re: table saw
Darrell
>I read a lot of reviews about the craftsman,about 75% said it was very hard to set and get everything adjusted.Other then that they were all very pleased with the saw. Did you have this problem? Thanks
