elongated holes
elongated holes
elongated holes
Dan Collins
>Friends: I am just completing a cherry computer table with breadboard ends. The table is all hardwood so I decided to accomodate the wood movement on the top with pegged breadboard ends. The top is 50 inches long. The tenons on the ends needed elongated holes for the pegs. It was rather frustrating trying to elongate the holes on such a long piece of wood. I tried drilling two adjacent holes with a brad pointed bit, then I used a round file to try to connect the two holes. I read somewhere that I could drill two holes then connect them by using a coping saw after threading the blade through one of the holes, then reattaching the blade. That definitely did not work beacause I couldn't get any leverage to reattach the blade. I thought about trying to use my plunge router to make the holes, but I thought it was going to be difficult to support the router over the tenon. With a pegged breadboard, the holes need to be parallel to the edge of the wood so that the breadboard stays tight to the top when the top expands, so the elongated hole needs to be made with some precision. I ended up using a round file to do the job, but I wasn't really satisfied with how that worked out. As I type this I am thinking that maybe I should have drilled two holes and used a chisel to get rid of the waste between the holes. Since so many projects call for elongated holes, I am wondering if there is some tool or method out there that makes this job easier and more precise? Any suggestions? Thanks. Dan
Re: elongated holes
Re: elongated holes
Stuart Hough
>Dan,
Rockler sells router bits that will do what you want. They have one for panhead screws (flat on top) or for standard wood screws (wth the 82 degree angle to match the screwhead. Not sure of the part numbers, but they were in the catalog from December. Good luck.
Re: elongated holes
A router will do it
>I suggest clamping a fence across the tabletop and routing the slots with a small plunge router. You'll probably want to tape an outrigger under your router's base to support it at the height of the top surface.
Another option is to make a little guide for a template bushing. It could be a strip of 1/2" plywood or MDF that you clamp over each tenon in turn.
Ellis Walentine, Host
