Burl cap
Burl cap
Burl cap
Mike Schwing from Maryland
>I've had this maple burl cap lying around for years, never quite knowing what to do with it. I've had several ideas, all gone by the wayside. So I finally dug into it with the carving tools. The pointy ends were just too cool to remove, so I left the bottom natural, and the interior follows the natural, wavy contour of the exterior of the cap. Finished with shellac, it is nearly 20" across the long dimension. Comments welcomed!
If the photo looks unusually colorful (click on the small one to get a larger version please) it is because I've been experimenting with HDR (High Dynamic Range) photography. You take 3 exposures of the same scene and "blend" them together. One exposure is normal, the other two are +/-2. The results are quite stunning!
Re: Burl cap
underside
Re: Burl cap
That will really look great with
Keith Newton
>chips in one end, and cheese dip in the other. You are going to be the hit of the party man!
And I hope you know I am kidding. It looks great.
Re: Burl cap
Jason Roehl in Lafayette, IN
Please expound...
>...on HDR photography a bit for us, could you, Mike? Are you doing this with a digital SLR camera and combining the photos in software? Plain-Jane digicam? Does the camera have the feature? Or, are you doing this in film? If in film, do you have to shorten the exposure time since you'd be exposing it 3 times?
Thanks,
Jason
Re: Burl cap
Re: Please expound...
Mike Schwing from Md.
>Jason, there is a lot more on the internet than I can tell you, but I'll give a nutshell of what I do.
First, I have a Olympus C700 zoom, it is a nice camera, but not a SLR, and it is only a 2.1 megapixel as well. It does have fully manual mode which I use for the HDR.
I take 3 exposures - all in TIFF format. RAW would be better but my camera is old and doesn't support RAW. The first photo is correctly exposed, the next is +2 and the third is -2. That produces one photo that is way overexposed but shows the shadows very well, the other is very dark. I use Photomatix software (free w/ limitations) to combine the 3 images automatically into an HDR, then do the tone mapping myself. HDRs can be done manually in the GIMP, and I believe there is a Photoshop plug-in that will do them for such users.
You can create stunning photos with HDR, and make them look as realistic or as surrealistic as you like. Either way - the results are stunning.
Hope this helps some. Much better info for the googling.
Re: Burl cap
Re: Please expound... *LINK*
>>...I believe there is a Photoshop plug-in that will do them for such users.
I don't know about a plugin, but this can be done manually in Photoshop with layer masks.
If you have enough dynamic range in a single image (you can see is detail on both ends of the range while adjusting brightness), you can also use a technique called Contrast Masking. This is especially useful where it is not possible to take more than one exposure, such as for photos of things that move (like people) and for existing photos. Contrast Masking is an old darkroom technique.
Contrast Masking
