Using 8" blade on 10" TS
Starry Chan
>Other than the depth of cut, what are the issues of using 8" blades on 10" TS?
TIA for your inputs.
Re: Using 8" blade on 10" TS
Dave's Not Here
>As you stated the depth of cut, other than that I can't think of any.
>If your saw has a splitter (which it should!) or a riving knife then there will be greater distance from the back of the blade to the splitter.
Tom
Brian in Brighton
>Depth of cut. I am not sure about hole diameter, might be smaller on the 8 inch.
Brian in Brighton
I like it for several reasons
Keith Newton
>A thin kerf blade will be stiffer for the same kerf width.
It is usually a little cheaper.
There is more torque the closer the teeth are to the arbor. This may not be an issue on a saw with plenty of power, but for a lot of people with contractor saws, this can be a big advantage.
Even though I have a 2 hp motor on my little 9" contractor saw which I take out to job-sites, I will stick a 7.25" on when I need to do a lot of ripping. However for finish plywood, I use an 8" fine ATB. I don't remember the tooth count, but I have tried it on my unisaw, and like it fine for that saw. When I have a fine finish blade on the TS, I can't think of a reason to have the blade all of the way up if it is a 10" blade.
Scott in Montana
>I might be missing something here, but I would think about the number of teeth, the speed of the blade, and the angle of attack. A larger blade would have more teeth with larger gullet area for clearing the waste. The teeth may have less torque on a ten inch blade but they have a heck of a lot more speed and inertia. And finally, Forrest recommends raising the blade quite high in order to give the teeth a steeper angle when it contacts the wood and therefore lessening tear out.
I suppose all of this is subject to debate, but those are my initial thoughts.
Scott
Robert R Clough - Thorncraft
>I have a very thin 7 1/4" blade for a portable saw which I use to cut boxes for top and bottom. As far as I am concerned any blade that fits and works for whatever purpose is fine.
Andy in Raleigh
>If it is an oddball blade to cut a material I am not likely to use often, I will opt for the 7.25" so it is cheaper and can be used with the circular saw. Wood is the only material I am likely to ever need full height for.
the story behind Forest's recommendation
Bill Tindall, E.TN
>It is not safe to cut with a blade extending much above the piece being cut. Bad cuts, when they occur , are preferable to amputations. So why would Forest recommend such a practice?
I bought a WWII blade a few years ago and found it gummed up and dulled quicker than what I was accustomed to. So, at my next visit to IWF I confronted the Forest people about this experience. I was told, " raise the blade up and it won't dull as fast". To which I replied that I was not interested in a blade that required using it in this way. I have not been a fan of Forest ever since.
In the mean time, I asked about this gumming up issue at a near-by saw manufacturing shop (Misenheimer). They showed me how the Forest blade has little side clearance (which results in smoother cuts, at a price) and as a result the blade loads up quicker with wood resins, even in hard wood. Once the teeth begin to load it causes enhanced dulling. They went on to say that when customers allow it they grind some clearance behind the top of the tooth and that reduces this deficiency.
one significant advantage......
Bill Tindall, E.TN
>The smaller blade will be safer. I keep a 7 1/2" blade on my 10" saw. I find that it is not prone to kick back and it doesn't throw cutoffs. The cutting force is also vastly smaller resulting in better control of the work being cut. I can cut just shy of 1 3/4" with this blade.
knotscott
>You're correct AFAIK, Scott. The smaller circumference does make at least minor differences in the aspects you mentioned....blade speed, attack angle, gullet size. An 8" version should still work, and would likely still work well if a 10" version does, but those are physical differences.
