Lighting in Display Cabinet
JohnM in Mid Mich
>Building a cherry display cabinet to house my old camera collection. Thinking about putting rope/cable lights inside the front corners. Main carcass of the piece is about 50 inches tall, 34 inches wide, and 12 inches deep. Somewhat remotely Arts and Crafts-ish design. Any recommendations? Are LED's appropriate/affordable? Vendors? Thanks, John
Re: Lighting in Display Cabinet
Alan Young
Consider Tape Lighting *LINK*
Alan Young
>I built a pair of bookcases where the clients wanted some lighting.
I lined the inside of the face frames with Tape Lighting. This product features a series of low voltage 1-watt bulbs that run off a 24-volt transformer.
Check out the link below for more details on the lighting system.
Alan
Tape Lighting
Re: Consider Tape Lighting
JohnM in Mid Mich
>That is exactly the look I want. Thanks.
John
Jennifer@Indy.USA
>Alan these looks really nice. I've been wanting to either build or buy a glass enclosed display cabinet to house my growing collection of turned objects. The light choice is a factor because of the heat. I have used the rope light under cabinets and they do get hot. Hot enough to make the clips that hold them brittle and eventually break up. How are these tape lights with the heat? I can't have heat build up in an enclosed display cabinet with wood turned do-dads.
Thanks,
Jen
Mike in Savannah
>I'm looking into using LED's, but at the "component level" for a low heat, low profile and very focused light source. There are many, many choices out there but to do this you'll need to know something about electronics, at least at the level of powering LED's (DC supply voltages, current limiting resistors, etc). This is not a very cheap way to accomplish this but you'll likely to never have to replace a bulb, use very little power and as small as 30awg wire.
Try looking at Newark electronics: www.newark.com then search for: LED
(Nice looking cabinets Alan! Thanks for that link for tape lights. I'll use those too for sure)
Alan Young
Re: Consider Tape Lighting *LINK*
Alan Young
>Jen-
We chose this tape light system because of it's low heat build up qualities. The bulbs are each 1 watt. You can purchase the system with the lights spaced every 2", 3" or 4" as per your requirements. I think this project had them spaced 3". More pics are here:
http://woodwardwoodworks.com/CottageBookcases.html
OR below is the Shop Shot of the building process. E-mail me if you have any further questions.
Alan
Illuminated Bookcases
Re: Heat buildup
Joanne Adler in Pt. Pleasant, PA
>Alan, what about the transformer? Does that heat up much? I have kitchen cabinets that have wires waiting for undercabinet lights. The guy who built the kitchen had planned on similar lighting. It's in the barn, but the transformer looks huge and as if it would get really hot. I'm looking for an alternative.
Alan Young
Re: Heat buildup
Alan Young
>Hi Joanne,
I don't recall transformer heat being an issue, but I'll contact the customers and ask if they notice anything regarding the heat. I know that all the other options we looked at were unsatisfactory, either because the lights were too obtrusive or hot-(we first looked at using halogen puck lights).
The transformers are large so the space they consume should be planned for. I used one transformer for both cases. In this project I though about using two smaller transformers-but it was decided that one larger transformer would be fine.
Alan
Cheap, Simple LED's *LINK*
JohnM in Mid Mich
>Thanks to all for comments. Haven't decided what to do yet, but here is another option, I guess: get a string of LED Christmas Tree lights... I could probably tuck these tightly into the front corners, maybe even do some judicious cutting and splicing?
70 LED White Mini Lights Set
Thanks Alan. Much appreciated!
Jennifer@Indy.USA
