contact cement for copper sheeting?
amateur table maker
>Hello,
I'm planning on making a dining table with a top of copper sheet metal. I've read in several places that you cannot use contact cement with copper, but I don't know why. Anyone have info on this or suggestions for another type of adhesive? I plan on using 20oz copper and mdf as the substrate.
Thanks in advance for any advice.
Re: contact cement for copper sheeting?
Rich Schneider
>Use two part epoxy..I am going to assume that you are adhering this to a plywood substrate of some sort or similar..rough up the back of the copper sheet with coarse grit sandpaper to give the copper some tooth. Then use epoxy (West system two part or similar) to join the sheet to the substrate. If you have access to a vacuum press that would be ideal for applying the clamping pressure.
Rich Schneider
>Oh, and one more thing, for the area where you don't want epoxy to adhere (say along the edges of the substrate)dress them up really good with beeswax.
Dick Coers
>Gorilla glue works great. Lots cheaper than epoxy.
Howard M
>Pliobond Industrial Contact Cement: label says it works with steel. Don't know about copper but you can check with manufacturer.
Howard
amateur table maker
>Thanks Rich. Just a few more questions if you don't mind. I'll be covering two separate 3' square pieces of mdf with the copper. When I mix up the epoxy should i apply it to both the copper and the mdf? Also, what method of application do you recommend to apply a thin and level layer that will allow the copper to lay flat without bumps? From the few times i've used 2 part epoxy, it seems that a large batch will be thick and hard to spread thinly and evenly over a large area. Any thoughts?
thanks a lot!
Rich Schneider
>What I've done is use one of those metal mastic spreaders that has the tiny little ridges (1/16 or so) on the spreading edge. That has worked well for me to get the correct amount of epoxy spread and leveled. Put it on both the copper and the substrate. Check your open time (don't be using 5 minute epoxy). If necessary have a helper available to assist with application and assembly. It is a good idea anyway so you don't screw up your copper sheet. I haven't used Gorilla glue on copper sheet before, but I would be concerned with problems related to foaming if you don't have a perfect means of applying uniform pressure over the sheet..at least I'm not brave enough to try it with an $80 sheet of copper...but if you do go that route I would be interested in knowing how it works out for future reference
Rich Schneider
>Another note...the sheet of copper on the table in the photo is 24oz (20 gauge)
Pic 1
Rich Schneider
Pic 2
Rich Schneider
>Pic 1 . back of copper sheet roughed up with 36 grit..24oz sheet...use common sense when roughing it up...Pic 2, spreaders, West sytem 105 epoxy, 206 hardner
Jesper, Denmark
Jesper, Denmark
>You have a potential problem in that vapors from the drying of the contact or other adhesive will not pass through the copper and only poorly through the MDF.
I have used epoxy (basically no off-gassing) or I have drilled relief vent holes in the substrate to avoid bubbles forming later.
Nice patina
>Is it clear coated?
Clint
>I have used water based contact cement to adhere copper sheet to door panels with no problem. The substrate is 1/8" tempered masomite wall paneling.
Clint
Another possible option
Curt Harms
>Roo Glue clear. It's advertised for melamine but I've glued aluminum T track to plywood substrate with very good success. It looks like an emulsion, has about 20 minutes open time 4 hours to pretty well set. No foaming or pot life issues. I'd certainly try it on scrap before committing a major project but it's cheap and I've had great luck with it. Not widely carried like Franklin Int'l products though. Woodcraft used to carry it until Titebond came out with a melamine glue. Woodcraft now carries the Titebond product and apparently dropped the Roo Glue. Too bad.
Curt
Re: Nice patina
Rich Schneider
>No clearcoat...just several coats of Renaissance wax put on with a power buffer and lambswool
