Air Compressors
Air Compressors
Air Compressors
Bill P
>I am planning on buying an air compressor. I was leaning towards the porter cable. Does anyone have any recommendations? I will mostly be using it for nailing and spraying varnish and stain. Also what pressure do I want for a high volume, low pressure air gun? Any help would be appreciated. Thanks, Bill
Re: Air Compressors
Rick L
Re: Change your approach...
Rick L
>and seek the gun first and match the compressor to the gun. Any compressor will work with nail and staple guns. Typcially you need at least 3 hp for a spray gun. There are some guns that will work with a small compressor but you will pay more than you expected. www.homesteadfinishing.com and I'm sure others will suggest spray gun sites.
Re: Air Compressors
Re: Air Compressors
>Your HVLP gun will think it's being waterboarded unless the compressor can push gobs of air. If you're limited to a portable compressor, I suggest you look for a conventional gun that's less demanding.
Clint
Re: Air Compressors
Re: Air Compressors
Hank Knight
>Bill,
Before you buy a compressor, check the air volume requirements for your HVLP guns. It's not pressure you need to be concerned about but the volume of air the compressor can supply continuously, measured in cubuic feet per minute or "CFM." Most HVLP guns require lots of air volumne (high CFM) to operate properly. A small pancake compressor may supply 2 to 5 CFM at 90 psi which is fine for brad nailers and such, but inadequate for a spray gun that requires , say, 12 CFM. Also, most pneumatic tools like sanders, drills, die grinders and such, use lots of air. Most compressors today will provide plenty of pressure, usually up to 120 psi or more. but the small ones can't supply lots of CFMs.
CFM specs are given at various pressures, usually at 90 PSI and 40 PSI. A compressor that can provide 5 CFM at 90 psi will give you more CFM at lower pressure - say 7 CFM at 40 psi (I'm pulling these numbers out of the air - no pun intended - for the purpose of this description, so they won't be terribly accurate for any given compressor.) Check the CFM requirement at the operating pressure of your tools to be sure the compressor can provide an adequate air supply. Many HVLP guns require 8 to 15 CFM at 40 psi to operate properly. The specs usually recommned a compressor with at least 3 to 5 hp to produce that volumme of air.
The size of the tank is important for high air use tools. A 60 gallon tank stores lots of air. This means the compressor doesn't have to cycle on and off as often to fill the tank as the air is used up as one with a 10 gallon tank. That in turn means less wear on the compressor.
Oiless compressors are great from a maintenance standpoint because they dont require oil changes. The trade off is that they are noisy (read: VERY LOUD) and they don't last as long as oil bath compressors. Even so, they will probably last forever in a hobby shop where they are not running all day, every day like in an industrial environment. I bought a 3 hp oilless Makita hotdog compressor that provides 9 CFM at 90 PSI. But when I spray with it, it runs all the time and sounds like an artillery barrage; it is so loud I can't stay in the same room with it. I wish I had bought an oil bath compressor just for the noise difference.
One last thing: If you haven't committed to an HVLP spray gun yet, some of the modern ones are designed to operate at much lower CFM than earlier guns. This means you can get away with a smaller compressor. I bought a nice gun from Homestead Finishing Products (Jeff Jewett's company) that operates at < 5 CFM @ 40 psi. It works great with my little compressor.
My $.02
Hank
Re: Air Compressors
Re: Air Compressors
Larry Clinton At Frankfort (Central)., Indiana
>Bill, PC compressors are built by Devilbiss (as are many of the lower cost compressors). You did not say what type / size of compressor you are looking at, I personally would stay away from the oil-less type as they do have a limited life. I say this with certainly as I know the motors built for these units required a certain hours of life test while powering the compressor on test beds. In almost every case, the compressors had to be replaced to allow the test to be completed. The oil type, properly maintained, will last many years. I don't believe PC builds anything but oil-less in the portable type. I purchased a Campbell Hausfeld stationary unit 60 gal 6 hp (probably a true 2 hp)severe duty with solid cast iron head. It has been in my shop for about 4 years with no problems. I'm not sure about the aluminum heads with the cast sleeves, they may be fine - but as an Engineer, I was concerned about the differential expansion and being able to remove and reassemble the bolts in a few years if necessary. The cost difference is pretty small between the cast and aluminum so I didn't take any chances. If you really want or need a great long lasting, efficient compressor, look at the 2 stage Ingersoll Rand or other quality units - but be prepared to pay!
Re: Air Compressors
go for the largest ...
M Meyers
>once you air, you will most likely start wanting more and more. therefore, oversize your compressor to what you think you'll need. you will save time and money in the long-run.
i wish i had had this recommendation when i brought a compressor into my shop.
this is the smallest compressor i'd get now:
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_211720_211720
this is what i would have gotten:
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200350476_200350476
Re: Air Compressors
Re: Air Compressors
John Ross
>Hello Guys, when it comes to this site, I am a beginning woodworker, but I spent 12 years as an air compressor mechanic and service manager. We worked on everything from fractional horsepower piston units to 1000 HP rotary screw units.
The gentlemen before me have given lots of good information. I will offer the following: DO NOT buy a Sears air compressor because it is difficult to get parts for and you must buy from Sears. If you are looking for a high quality, relatively inexpensive and easy to repair unit, I would recommend Emglo. They are often sold at dealers that sell to contractors, they are typically oil lubricated and parts are readily available and cheap.
Other nice units that show-up in the tradepapers as used are Ingersoll Rand T-Series units (I really like the model 242) and Champion's Model R15 units. Again, cast iron, oil lubricated and a full 3- 5 HP with 1800 rpm motors. I like the slower motors rather than increasing the output by turning the unit twice as fast. Also look for units with individual valves rather than valve plates. Some of these units are no longer made, but parts are readily available and because they hold up I have seen units around that are 20-40 years old. You may call an air compressor company and see if they've taken any in trade. Quincys are also wonderful machines. The best part, the older ones are made in the USA.
Good Luck, John in Rhode Island
Re: Air Compressors
Re: Air Compressors
Bill P
>Thanks for all the great replies. Off to get my checkbook. Do my part to stimulate the economy. LOL Bill
