OT Splitting cable signal question
Nat Robison
>I need to add a splitter to my incoming cable for a new cable outlet in the basement.
I've heard that splitting the signal can weaken it.
My basic question is, does the signal degrade only if there are multiple TVs on at the same time. Does is matter if the signal is digital cable (which we have) or analog?
Re: OT Splitting cable signal question
Ron Hildreth
>Nate,
Never heard of such a thing! We have four TV's, all of which have been on at the same time, and couldn't see any difference. All of ours are digital, too.
Just make sure the connections are of high quality (gold) and are nice and tight, you'll be fine.
Ron in Iowa
John in NM
>Not sure about digital cable, but in general, splitting a RF signal on a coax cable will weaken it some. How much you loose probably ends up depending more on the length of the cable run, though the split loss should be a fixed amount. Having the TV off won't help. If you've got a good signal now, and you're just adding a single split with less than 50' of standard wire you should be fine.
Jason Roehl in Lafayette, IN
What various installers have told me...
>1. If at all possible, split the signal only once. If you have 4 TVs and a computer, split it 5 ways whereever it's convenient to do so. Don't "daisy-chain" the splits. Get a cap for any unused places on the splitter.
2. Most signal loss occurs at the connections. It pays to have good ones. Use good splitters, and for the terminations, the new compression-style fittings are the berries. (I bought the tool and some fittings before I learned that our cable company would give us just about any length of RG-6 with both ends terminated for free.)
3. Two-way digital is the most susceptible to the above issues, particularly broadband internet, and to a lesser degree, a digital cable box or DVR.
Jason
Amplified splitter
Robert Henderson
>They do make amplified splitters.
I wired my house for cable. I have an 8-way amplified splitter in the basement. one connection goes to my cable modem, the rest go to various rooms throughout the house.
If a connector is not used (either at the splitter or at the wall plate in a remote room) you will have to add a terminator ( little cap with a resistor in it that screws onto the cable connector) to avoid signal reflection (don't ask me, I don't understand it either).
I needed to do this because I had long cable runs to the upstairs bedrooms. Once I got to the room with the amplified signal, I could use local splitters (e.g. from the wall to a TV and a computer) without further amplification because the runs were so short.
Hint: the amplified splitters that Radio Shack sells will not do it.
Re: OT Splitting cable signal question *LINK*
>Every time you split a cable signal, analog or digital, you reduce the signal strength by some amount. With enough splits, you will eventually degrade the signal too much. The number of useful splits is determined by the strength and quality (signal-to-noise ratio) of the incoming signal and the quality of the splitters used and cannot be determined ahead of time. At my last residence, the cable signal was in fact so strong that the cable company had to put an attenuator in-line to reduce the signal. I split that line into seven. My current installation here at the farm splits 5 ways, one to HDTV and one to internet cable modem. This is after running over 600' underground from the pole and who knows how far from nearest system amplifier. Other installations have the opposite problem of not enough signal and/or a noisy signal.
Best thing to do is try it. You may be able to get or purchase high-quality splitters from your cable company. Mine gave me a handful, connectors, and part of a roll of cable. Of course I talked nicely to them and offered them glasses of iced tea.
It is usually better to use fewer multi-way splitters than chaining a number of two-way splitters because each connecting wire you add can also reduce the signal. Quality connectors and cables also help. If the signal is too degraded to function properly, it can sometimes be corrected with an amplifier but this is tricky. Most of the amplifiers readily available to consumers that I've seen introduced too much noise.
If you have problems, you cable company, if they are nice people, may help. Comcast came out to my house, added quality splitters, and tested each line with a signal strength meter.
Mr Google had a lot to say about this. The link below is the first one I checked and it doesn't seem too bad.
one google hit
Joseph Mulherin, Sr.
>I have five TV's on a split cable system and my computer system is also on the TV signal.....and everything is working fine.
Technically
Dan Donaldson
>Every time you split a signal, you cut it by half. If you use a three way splitter, the signal on each leg would be 1/2 of the original on one and 1/4 on the other two, on a 4 way, 1/4 or 1/16 depending on how it is configured). It doesn't depend on whether there is anything connected or not. (except that you should have a terminating cap on unused connections or it might be worse than that). A passive splitter will always have these losses.
The other question is whether it matters or not. If you have enough incoming signal, it won't make any apparent difference, if the incoming signal is marginal, it can make a lot.
Ken Garlock, Collin County Texas
>Hi Nat. It is really a matter of division. You split anything in half and you have half of it in one half and half of it in the other half.
When you use a splitter on a piece of coax, you will have half of the signal go in one direction, and half in the other. IF you add yet another connection ( a 3 terminal splitter) you will have one terminal getting 1/2 the signal, and the other two terminals getting 1/4 the signal, half divided by two. Add yet another terminal for a total of 4 and each terminal will get 1/4 the signal. Inside that little container with the terminals attached are some coils, capacitors, and possibly resistors to make sure the TV on the other end of the coax likes that it sees, a 75 ohm interface.
On the splitter label you might see an indicator of how much the signal is reduced at each terminal. For a simple 2 output splitter, it will say "-3 db." For a 4 terminal output, you will see "-6 db." A change of 3 db means that the signal has been reduced (-) by 1/2 or increased (+) to twice its original value. 6 db means the change was a factor of 4.
Sorry you asked, right. Just go ahead and get a splitter and hook it upusing some good RG6 coax. (Good coax is spelled B.E.L.D.E.N.) In the end, the TV will tell you if it is working.
Good Luck on your project,
Ken
Thanks for the feedback
Nat Robison
>Thanks for all the responses. I already had a 3-way splitter and swapped it out for a 4-way splitter. No discernible problems with the signal.
It makes me think that, in general, the signal from the pole to the house must be quite strong if you can divide it 4 or 5 times with no detectable loss of quality. We must have decent cable quality here in Metro Detroit. Thanks again.
Quality
>"....We must have decent cable quality here in Metro Detroit...."
Personally I don't think that you'll find as much technical quality issues with cable as you do programming and content quality ;)
Happy Woodworking!
Re: Quality
Bill Howatt
>You've got that right although not everything is garbage. My biggest laugh is people getting HD TV to watch the crap in fine detail. HD fixes the wrong end of the problem; I've never heard anybody say they didn't want to watch a program because the resolution was inadequate.
Bill
Jerry Samsen
>A passive splitter halves the signal. Optimally, you want no less than 0 dBmV (1mV) of video to the video device.
Rather than explain, take a look at the video distribution tuitorial at this link. The entire link budget should be considered including cable runs, splitters, and amplifiers if used.
Video Tuitorial
Quality, history *LINK*
>>...you'll find as much technical quality issues
I was reminded this weekend of Newton Minow, the FCC chairman, in his 1961 speech:
"When television is good, nothing -- not the theater, not the magazines or newspapers -- nothing is better.
"But when television is bad, nothing is worse. I invite each of you to sit down in front of your television set when your station goes on the air and stay there, for a day, without a book, without a magazine, without a newspaper, without a profit and loss sheet or a rating book to distract you. Keep your eyes glued to that set until the station signs off. I can assure you that what you will observe is a vast wasteland.
"You will see a procession of game shows, formula comedies about totally unbelievable families, blood and thunder, mayhem, violence, sadism, murder, western bad men, western good men, private eyes, gangsters, more violence, and cartoons. And endlessly commercials -- many screaming, cajoling, and offending. And most of all, boredom. True, you'll see a few things you will enjoy. But they will be very, very few. And if you think I exaggerate, I only ask you to try it."
And this in 1961? The entire 1961 is interesting (link)
"Vast Wasteland" speech
Jesse Cloud
>For what its worth, I hooked up a splitter behind my cable modem thinking that for a special occasion we might wish to put a TV near the computer. The TV leg has a cable on it, but its not attached to anything. Internet speed to my computer is delightfully fast. So, at least in this particular case, it doesn't really matter.
Re: Quality, history
Curt Harms
>In 1961 it might have taken all day before You were either ready to go postal or run around in circles pulling your hair out. Today it only takes a couple hours;-). Thank goodness for Discovery and A&E TV.
splitting ..no problem
robert davis
